  • June 16, 2025, 10:13:38 PM
Author Topic: Skimmer & Nostalgia  (Read 4022 times)
Offline Mike Anderson
Skimmer & Nostalgia
« on: September 27, 2009, 10:41:21 PM »
I decided that the original discussion of the XF5U-1 Flying Flapjack was pretty off topic in what started out as a thread about .15 Carrier - perhaps we can have at least ONE thread that doesn't turn into a trolling match, an MO1 bash or a flight realism session -
So first off, thanks to Bob Heywood for the support packet he sent me - as previously mentioned this was the very first Navy Carrier event plane that I ever saw and it was the first time I had even heard of Navy Carrier - this was in the summer of 1974 in Sioux City, Iowa.  I don't know if the flyer ever managed an official flight with it, but it did get me interested in the event -
So my own "Nostalgia" event would go back to this model -- though I had never built one until a couple of weeks ago.
It has a Max-III .35 which was originally RC (with a flapper valve intake and rotating exhaust baffle) but I had removed those long ago to use it in Sport Racing (this ain't no Stunt motor! -- it goes pretty good).  I tried to run it first with an Irvine carb off a real old K&B .40 but the carb was, well, I can understand why K&B gave up on them, so I swapped in a Magnum .36 carb which idles very well.  Actually the original carb/baffle idled as well as most modern carbs but I had to mill off some metal way-back-when to fit the racing venturi and couldn't get it back on again.  Anyway, I have been test running it on some 25% Nitro, mostly Castor fuel on a Skyray and it seems to be pretty quick, so I am anxious to get it flying - hopefully this weekend.
Mike@   AMA 10086
Central Iowa
david smith
Re: Skimmer & Nostalgia
« Reply #1 on: September 27, 2009, 11:16:02 PM »
That looks AWESOME!  I cant wait to see it fly.  I remember seeing one a long time ago(my long time ago isnt that long ago to some) at Topeka but I have no idea when or who's it could have been.  What is the wing area?
David
« Reply #2 on: September 27, 2009, 11:30:36 PM »
Wing area is almost exactly 300 sq. in. PLUS the 'ailevators' as they called them back in 1948.  It weighs a whole 34 oz. - that 43 lb. pull test is already scary --   n~
Mike@   AMA 10086
Central Iowa
Offline Wayne J. Buran
« Reply #3 on: September 28, 2009, 04:02:57 AM »
Mike, very nice job, looks like it should fly well. Thanks for the shots especially the uncovered ones. Where is fhe CG and do you have a weight?
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
Offline Peter Mazur
« Reply #4 on: September 28, 2009, 07:26:09 AM »
This is a great job, Mike. I very much look forward to seeing it fly next summer.
The previous thread did, indeed, get off topic on this. In that thread there was some confusion about scale points in regular Profile for this model that never got clarified before we all shut up. So I just wanted to clarify: The records indicate that the prototype never flew before being scrapped. As a result, it is not eligible for scale points in any AMA class, even though it was intended for carrier use. If someone could document a test flight, that would be great and we might see more of these.
But I understand your enthusiasm for this model and agree that it's worth it, never mind scale points.
Pete
« Reply #5 on: September 28, 2009, 07:50:10 AM »
Well this is for Profile Nostalgia - no Scale points anyway.  I don't want to get any further into that  subject in this thread.  I will be happy with the 20 point 'Historic Model' bonus & the plain-bearing engine bonus.  I hope it will do 80 Hi/ 20 Lo  (& I intend to hang it as nose-high as I can manage to get it!!!) S?P     No- forget I said that ... I still want this thread to be about current & new Nostalgia models & Nostalgia flying.
Mike@   AMA 10086
Central Iowa
« Reply #6 on: September 28, 2009, 08:04:37 AM »
Wayne
I had wanted to do a build-log on it so I took a couple of pix after I got it framed up.  Then it went together so fast and easy, rather than sit at the computer I just kept working on the model and finished it up.  I actually had it at the field Saturday, made a new set of lines for it, adjusted the carb, got it all fueled up - then stuck my finger in another guy's prop (don't ask  n~) and had to trundle off to the emergency room for stitches.  So maybe this Saturday ...
It weighs 34 oz. at present - most models gain a few ounces while getting them trimmed, but I don't think I'll ever need to pull 50 lbs (40 oz.) with it.
Balance point is right around the spar - if it needs nose-weight or tip weight I can put it in the outboard boom - Bob mentioned some trouble with the booms on the original so mine are a core of hard 1/4" balsa with 1/8" light-ply doublers full length, both sides.  They ended up weighing about 1.25 oz. each, so I was OK with them - they are very rigid & we will just have to see how they hold up.
Mike@   AMA 10086
Central Iowa
« Reply #7 on: September 28, 2009, 08:36:29 AM »
Mike, thanks for the info, looking forward to the flight news. Did you need stitches?
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
Offline Dennis Saydak
« Reply #8 on: September 28, 2009, 08:54:43 AM »
Very nice work Mike. I love that model (it's so unusual) and hope to build one in the future myself. I have original drawn plans for it that Gary Hull sent me a few years ago. It may have some modifications but I don't recall for sure. Perhaps Gary can comment?
Our club just had a second circle added to our flying field this year and the plan is to include a carrier deck next year. In the meantime there will be a few carrier models built this winter by our members.
Just when you think you're getting ahead in the rat race.....you find the rats just get faster!
« Reply #9 on: September 28, 2009, 09:09:48 AM »
Wayne
It took four stitches to close it up - I had feared it would need some "sub-cu" or below the surface because it was really deep, but he just stitched the surface closed - I told him if I'd known that was all he was going to do, I would have just super-glued it ... and gone ahead and flown.  Now I have a wad of gauze that is too big to get through the trigger on a J-Roberts handle ... Saturday we have a picnic/fly-in at one of our club-members house.  He lives out in the country and has a circle in his front yard - I'll have someone take some shots from his front steps which puts you above the circle so they should be pretty interesting.
Mike@   AMA 10086
Central Iowa
« Reply #10 on: September 28, 2009, 09:19:33 AM »
Very few mod's to the original plans are needed - the "C" rib is misdrawn on the plans - look at the picture above and notice the 3rd rib outboard has a new 'nose' section added to it in order to tie it to the LE.  You will have to get the throttle linkage from the inboard to the outboard side - a transfer crank similar to Pete Mazur's on his Brodak Guardian is what mine ended up using.  I can do pix if anyone needs them.  I also moved the leadouts back about an inch from where the plans show them.  They were going to end up right on the CG.  The elevator hinges could be done in a simpler fashion, but I used those shown on the plans.
Great news about the new planes & possible new deck ... where are you located?
Mike@   AMA 10086
Central Iowa
« Reply #11 on: September 28, 2009, 11:21:15 AM »
Pete
I have to wonder -- Suppose these had actually made it to the fleet - Now further suppose you are a Chinese pilot in North Korea, flying along in your Yak-9 or some other Russian-provided piston-pounder, and as you cross the 38th parallel, southbound, two of these things roll in behind you ... what goes thru YOUR mind?
"Uhhm PyongYang ... we got a problem"
" It looks like the Martians have joined the US Navy .... uhhmmm, anyone know if they still have those death-ray thingies?"
"Hey .. is anybody there?"
Mike@   AMA 10086
Central Iowa
Offline Bob Heywood
« Reply #12 on: September 28, 2009, 02:23:11 PM »
Mike,
Nice work. Good luck when you get to fly.
Bob
P.S. For the throttle linkage on mine I used a piece of flex cable in the nylon tube. It attached to the same part of the 3rd line arm on the J. Roberts bellcrank as the leadout. A simple 90 deg routing under the tank took it right to the engine.
"Clockwise Forever..."
Re: Skimmer & Nostalgia (Revisited)
« Reply #13 on: December 01, 2010, 09:20:11 AM »
I just wanted to post some pix of the Skimmer we discussed last fall - so I decided to re-visit the original thread in case others wanted to see the background messages that spawned this model in the first place.
As others predicted in one of the threads, the landing gear sewn to the spar proved to be a poor idea for flying over grass.  The model hasn't got much of a glide and is nose-heavy, and if the engine quits with any altitude at all the resulting 'landing' turns into a cartwheel and the booms start tearing pieces off.
I did get some pix of it it flight before one of the cartwheels made some major repairs necessary.  Regretfully, I didn't get to it until THIS fall, so never got it flown at a contest this summer.
When I did finally get around to it, I redesigned the landing gear mounting-- hardwood blocks & torsion bar type landing gear with lite-ply doublers added to the ribs that support the gear.  I also added some tail-weight/tip weight to what was originally called out.
Managed a couple of flights last weekend and it flies pretty well - it seems fast enough and slow flight (1970's style) is quite good.   Touch and goes and low speed were much better that before and the model is a visual treat.  I'm looking forward to this spring and getting some official flights in at our spring contest (shameless plug - Mid-Iowa Spring Kickoff -- May 7-8th, 2011 -- Polk City, Iowa).
« Last Edit: December 01, 2010, 11:55:28 AM by Mike Anderson »
Mike@   AMA 10086
Central Iowa
Offline bfrog
« Reply #14 on: December 01, 2010, 04:11:10 PM »
Mike,
Very neat airplane.
Hope you stitches don't keep you down for long (haven't you heard of a chicken stick?).
Bob Frogner
« Reply #15 on: December 01, 2010, 10:41:59 PM »
The stitches were last fall - they weren't nearly the problem that the MRSA infection I picked up while in the emergency room getting stitched.  (MRSA is a drug resistant staph infection - there are only two drugs that presently treat it and some forms don't respond to those either. It took two rounds of one of them to clear it and I've had to be tested to be sure that it is still gone.)  Anyway - my finger healed in time for me to crash the plane last year at our club picnic.
And a chicken stick wouldn't have helped - I stuck my finger through the prop from BEHIND, while holding another guy's plane and trying to point to something that he was about to trip over in front of the plane -- totally my fault and a pretty dumb move.
Mike@   AMA 10086
Central Iowa
« Reply #16 on: December 01, 2010, 11:30:51 PM »
Neat model, Mike. Glad you got it going well. Finger too!
Chris...
Offline john vlna
« Reply #17 on: December 02, 2010, 01:04:37 PM »
Mike,
sorry about your finger, but glad your Skimmer flys OK. Most folks I have talked to that have built one don't like them much. My B-390 is a similar design and flies but you have to really stay on the ball with it. Most low aspect ratio CL designs seem to have fore and aft stability issues. The only one I ever had that flew well was a saucer with a hole in the middle.  I may try that with my B-390 since it is made of foam.
« Reply #18 on: December 02, 2010, 01:18:54 PM »
If I were trying to hang it on the prop and fly 30 second laps, I probably wouldn't like it much either.  But for flying in Nostalgia mode it flies pretty well - the engine idle is sufficient to have it fall out of the sky when you go to full idle so hitting the deck should be reasonably easy.  It doesn't seem as if it will be ballooning into the wind either, so that will also assist the landing.  I will add some more tail weight, because at present I can get it about to the angle shown in the pix, but not much more, with full up elevator - and it's still flying (not mushing and bobbing) around - probably has a two minute low in it or maybe 130-140 sec. if I can get the nose up a little more.  Then it's all up to how fast will it go - maybe 26 seconds or if I fool around with props/fuel 23.5-24.0 sec.   The old school type of flying doesn't lend itself to a whole lot of improvement anyway.   It's just fun to chug around 3 feet off the deck, do a few touch-and-goes and let the spectators scratch their heads and ask questions afterward.
Mike@   AMA 10086
Central Iowa
Offline john vlna
« Reply #19 on: December 02, 2010, 01:40:55 PM »
Should make a great Nostagia profile. I know what you are saying about getting the model up to 60 degrees. These type designs just don't like it. One that will is the geobat. It actually can fly the stunt pattern. Some day I'll make a carrier version
