  • June 17, 2025, 12:55:16 PM
Author Topic: my timer with gyro  (Read 1302 times)
my timer with gyro
« on: May 28, 2009, 05:50:05 AM »
it starts from "Max throttle" and subtracts power regarding actual speed
Re: my timer with gyro
« Reply #1 on: May 28, 2009, 05:51:52 AM »
ESC programming
« Reply #2 on: May 28, 2009, 05:55:06 AM »
timer programming
Offline John Cralley
« Reply #3 on: May 28, 2009, 07:03:19 AM »
Igor,  I've been waiting and waiting for you to update your gyro setup. I have a gyro in hand (E-Sky looks much like yours) but have not tried it yet.
1) How do you mount it on your plane?
2) I know your timer is self-designed but would a Z-tron, JMP or Will Hubin timer work here??
3) How about a wiring diagram or schematic??
This certainly excites me and I bet many others!!!
John Cralley
AMA 52183
Central Illinois
« Reply #4 on: May 28, 2009, 07:26:26 AM »
it is simply sticked on fuselage wall ... or you can see it on my indoor model ... the orientation must be that it makes impulses shorter if your model turns left - if not, just use the "reverse" switch and that is ... everything else is question of proper sensitivity setting (in gyro, in timer and afte all also in ESC if possible)
no, everthing is in that one device, you not need any extra timer
there is not schematics :-) ... everything is program in the device (as well as timer only and timer with 4-2-4 simulation) ... it has only connectors ... and to be sure one blocking capacitor, but I tested it all also without and never failed with switching BEC in Jeti spin ESC
