  • July 25, 2025, 12:17:44 AM
Author Topic: List Your Set Up...  (Read 230775 times)
Offline Dan Bregar
  • Field Marshall
Brodak Original Magician (Silkspan & Randolph dope)
« Reply #100 on: July 19, 2011, 07:33:32 PM »
W. Span        43 1/4"
W. Area         407 sq. in.
Weight           with batt. 35 oz.
Mtr.               Arrowind 2815/09  (Rear mount)
Batt.              Blue Lipo & Zippy Compact 4S2200 (25C)
ESC                Phoenix 35
Timer             Hubin FM-2SR
RPM               Gov. mode High RPM  10,050)
Prop               APC 10X 5.8EP
Lines              59 ft. eye to eye
Lap time          4.90 sec. give or take a freckle
Flight time       5 min. 35 sec. (Intermediate pattern)  uses about 1650 mah
Special thanks to Dennis Adamisin for his help in selecting E components
Over 200 flights to date and several contest wins.
« Last Edit: September 30, 2014, 01:16:48 PM by Dan Bregar »
AMA 33676
Offline Larry Wong
Re: List Your Set Up...
« Reply #101 on: August 17, 2011, 06:55:48 PM »
Ampura
64" wing span
670sq.
Plattenberg Motor Orbit 20-12
Hubin Timer FM-9
Shultze ESC F2B
Wt. 59 oz.
Battery Thunder Power 2600 mAh 5 cell 18.5 V
Prop. APC 13x4.5 EP
lines 65' Eye to Eye
flight time  5.25 min.
RPM 9488
1967-2100mAh used
lap time 5.4
Larry
Offline Fred Cronenwett
    • Lafayette Esquadrille
Great Planes RV-4
« Reply #102 on: August 22, 2011, 03:58:12 PM »
Great Planes RV-4 (sport kit) for CL scale
56" span, 650 square inches of wing area
6.5 lbs with 4S battery, 5000 Mah
The 5000 Mah is more battery capacity than I really need, I can get two complete flights out this battery
Eflite E-32 Motor
Castle Creations ICE 75 speed control
12" APC electric prop
57' or 60' insulated lines (2 lines for electronic controls)
Model is flown in CL sport scale with DSC electronic controls for flaps and throttle control
Model is fiberglassed and then painted with latex house paint and used vinyl decals for the G-CEVC
The original kit outlines on the horizontal and vertical tail were wrong so I replaced them with correct outlines from factory drawings.
I also added a scale tail wheel instead of the normal RC tailwheel.
Land softly,
Fred Cronenwett
« Last Edit: September 04, 2011, 09:20:22 AM by Fred Cronenwett »
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Percy Attfield
Child of Impact
« Reply #103 on: August 29, 2011, 01:36:47 PM »
The plane is a modified Impact renamed Centurion.
Wing Area 700 sq inches
Weight 66 ounces
Motor MVVS 6.5/910, the second number indicates the revs per volt
Battery 4 cell XPower 3300MAH
Controller 60 Amp Align and a Keith Renecle Control Line Timer
Prop APC 12X6
Line length 65 ft 9 inches eye to eye, 69 ft 3 inches total length
RPM 9,400
Lap time 5.2 seconds
MAH used per flight 2,400
Flight time 5min 40 seconds
Height above sea level 5560 feet
Temperatue 80 degrees Fahrenheit
The plane is a take apart; both wings come off, the fuselage comes apart into 2 equal sections, stab and fin comes off.
Has had 40 flights to date.
Percy Attfield - South Africa
Offline Crist Rigotti
« Reply #104 on: September 05, 2011, 08:16:23 AM »
Jamison Special
507 sq-in
38 1/2 oz
Scorpion SII-3020-890 kv
Rhino 4S 1550mah
Castle Phoenix 35A
Hubin FM-9
APC-E 11x5.5P
58 feet .012
4 min on time
9800rpm
5.2 sec
@1200mah used
Offline Keith Renecle
Re: Child of Impact
« Reply #105 on: September 24, 2011, 03:14:24 AM »
Weight 66 ounces
Prop APC 12X6
RPM 9,400
Here are a few photos of Percy's Centurion
Keith R
Offline Kerry Ewart
« Reply #106 on: November 12, 2011, 03:52:30 PM »
Model :-ex Joe Parisi "Novar",
weight :-68 oz
Motor :Arrowind 2832
ESC:- :Arrorwind 60a
Timer:-Hubin F2sr
lap:-5.4 to 5.6 68ft c-c lines
prop:- Apc 13 x4.5 EPP @ 11000
All i can say is its very impressive .It was retrofited just to test the setup and only had 6 flights @ 4.5mins and uses 2100 MA ,more flying today ,Cg was set at 18% approx and point the nose up and it does not stop and the pusher gives no shortage of line tension,Joe had the 5th flight and was even impressesed,
"If you cannot beat them!JOIN THEM.
Offline Peter Germann
Sultan-e
« Reply #107 on: December 17, 2011, 04:21:04 AM »
Sultan-e by Norm Whittle, Specs:
Span: 60.6 in (1'539 mm)
Area: 691 insq. (44.6 qdm), incl. flaps
Airfoil: NACA 016. modified to 17% thickness
T/O Weight: 60.1 oz (1'704 Gr.)
Finish: Oracover & spray can acrylic + spray can acrylic clear
Motor: AXI 2826/12 760
ESC: Castle Creations ICE lite 75 A  with Firmware V 3.26 (Beta)
Timer: FM-9, latest version with spike suppression
Battery: DesirePower V8 2600mAh 5S  (18.5V) 25C
March 7 2012 flight setup:
Temperature: 10° C
Alt. 352 m / 1'154 ft msl
C.G.: 15% MAC or 7.48 in (190 mm) from flap hingeline fwd.
Cables: 19-strand 0.015" (0.39mm) x 64 ft (19.5 m) eye-eye
Hingeline seal: both, flaps & elevators
Leadout (Center): 1" (26 mm) behind of C.G. or 6.48" (164 mm) from flap hingeline fwd.
Tip Weight: 1.48 oz (40 Gr)
Motor thrust angle: 0.5° down
ESC setup: Control Line, Governor high, Governor Gain 35, Timing 4  PWM 8Khz
Propeller: APC thin electric pusher 13 x 5.5 EP
RPM: 9'154
Lap: 5.50 sec
Delay: 30"
Run time: 5:20
Re-charge: 1'800 mAh (69%)
Peter Germann
« Last Edit: March 08, 2012, 03:10:26 AM by Peter Germann »
Peter Germann
Offline Peter Ferguson
« Reply #108 on: December 17, 2011, 07:39:57 AM »
Ampact
Modified Steve Moon Impact ARC
front mounted E-flite 32, apc 13 x 5.5 prop
ICE lite 75 SC
Hubin 9VR timer
TP 5S 2700mah battery
weighs 64.5 oz
5.5 sec lap times on 65' lines
Peter Ferguson
Auburn, WA
Offline keith varley
E.Sultan .and Son of Sultan
« Reply #109 on: January 18, 2012, 09:32:44 AM »
E-Sultan and Son OF Sultan
690 sq. inches
65 ounces and 63.75 ounces
Axi 2826-12
Ice Light 50
Hubin FM9
Maxx Products arming plug
APC 13 by 5.5 EP
.018" by 64 ft 6" eye to eye
5.min 30 sec
5.35 sec laps
TP pro lite 2600 MAH 5 cell
use 2020 MAH
« Last Edit: January 18, 2012, 10:16:40 PM by keith varley »
Offline John Castle
  • The Bent Pin
« Reply #110 on: March 09, 2012, 10:36:18 AM »
Loose interpretation of a 1/2a Pinto
Finished with Microlite, Japanese tissue and MinWax Polycrylic
AXI 2217/12
JETI 30 amp ESC
E-Flight timer
Turnigy 1000 3 cell Lipo battery
APC 8x6 EP prop
RTF weight of 14 oz.
42' x .008 steel lines
Still working on trimming but seems to fly just fine
The throttle is turned down to about 60%
At that throttle setting after a 4 minute flight my batteries are at about 65% charged. At that rate I should be able to easily get 6 minute flight times.
« Last Edit: March 09, 2012, 12:06:53 PM by John Castle »
John Castle
McMinnville, Oregon
AMA# 589650
Offline Bob Hudak
Legacy 40
« Reply #111 on: March 25, 2012, 08:02:06 PM »
Wingspan    53.75"
Wing Area   565 sq.in.
Weight       52 oz.
Lines          60'/.015
Battery      Thunder Power G6 Pro Lite 2700mah 25C
Motor         Emax 2826/06 850kv
ESC           Castle Creations Phoenix IceLite 50(set in hi gov. mode)
Timer         Hubin FM9
Prop          APC EP 11.5x6 f2b(cutdown 12x6)
RPM           9030@timer
Lap Time    5.3 sec.
Flight Time   5.30 min.
Mah Used      2013 mah
Great flying setup!
                 Bob
« Last Edit: June 25, 2024, 06:22:53 AM by Bob Hudak »
350838
Offline Chris_Burgess
« Reply #112 on: June 05, 2012, 08:05:51 PM »
Legacy
65' .018 lines, Tom Morris hard-point handle.
66 oz.
Cobra 2826-12 Brushless motor. 780kv
APC 13x4e
Turnigy 45a "Trust" ESC
Zippy Flightmax 5s 20c 4000mAh pack
Running 5:50 with a z-tron timer, it finishes the pattern and has about 15-20 laps to spare, doing almost exactly 5 second laps and a little under 2700mAh goes back into the packs.
100% power full time.
So after Flying the Legacy a few more times I figured I'd update a few things.  When I wrote it was running 100% power all I knew was that it was running at the max the timer could make it go, it turns out that the motor is mechanically limited with a 5s pack at about 10800 rpm so it was reaching that at about 82% of what the esc had in its throttle curve.  Any way, I now have it flying what feels like a very slow 5.3 second lap compared to the 5 second laps it was doing before. Thank you to everyone who made suggestions on how to improve it and a very special thanks to Mike Palko for all of his help in getting it off the ground in the first place!
« Last Edit: August 18, 2012, 09:26:48 PM by Chris_Burgess »
« Reply #113 on: June 08, 2012, 03:09:51 AM »
Specifications Max Bee
Date   June 8 2012
Type   Max Bee
Designer   Igor Burger
Builder   Peter Germann
Wing
Wingspan   1'500 mm (59 in)
Wing Area, incl. Flaps    42.5 qdm (659 in sq.)
Airfoil   Burger
Thickness (% MAC)   22 %
Empennage
Span   760 mm (30 in)
Empennage area in % of wing   31 %
Fuselage
Nose length              298 mm  (11.73 in)
Hingeline-hingeline   475 mm  (18.7 in)
Power Train
Motor type and Kv   AXI 2826/12   760
ESC   Castle Creations ICE lite 75 A
Timer   Hubin FM 9 / spike protected
Battery, type, capacity, no. of cells   DesirePower V8 5S 2600 mAh  60C  362 Grams/12.75 oz
Weight
Take-off weight   1'825 Grams (64.5 oz)
Lines
19-strand stainless steel, eye-to-eye   0.39 mm x 19.5 m (0.015 x 64 ft)
Trim
C.G. in % of MAC   20.7 %
C.G. from flaps hingline forward   180 mm (7.08 in)
Leadout setting (center, aft of C.G.)   19 mm (3/4 in).
Outer tip weight on scale   28 Gr. (1 oz)
Flaps-Elevators throw ratio   1:1
Hingeline sealing   Flaps
Propeller thrust line   +1° (up)
Angle of attack stabilizer   +/-0°
Handle spacing   110 mm (4.33 in)
FM-9 RPM set   9'553
Lap time (sec)   5.30
Electric Setup   Castle Phoenix ICE lite 75A
Motor start delay   30 sec
Runtime   5 min 20 sec
Laps remaining after clover   6
Propeller, type, rotation,   APC thin electric 13 x 5.5 EP (reverse)
Motor timing   4
PWM Frequency (kHz)   8 KhZ
ESC Mode   Control Line
Governing mode   Governor High
Brake strength   95 %
Brake delay   0.8 sec
Cutoff Voltage  18 V (for use with spark protection plug)
Auto-Lipo shutoff   3.0 V
Cutoff type   Soft Cutoff
Power consumption (recharge)    350 m/M 25°C, calm: 1'950 mAh
Peter Germann
« Last Edit: April 16, 2013, 04:06:54 AM by Peter Germann »
Peter Germann
Offline Ron Heckler
« Reply #114 on: June 16, 2012, 01:23:34 PM »
Original design RH Stunter - "SORCERER"
Bob Hunt "Caprice" foam wing - total span 51"
Covering - Ultracote with Monokote trim sheets
                 All hinges are made from Ultracote
Functional air scoops in front. Air intake hole at bottom front has baffle to direct cool air to motor and electronics inside.
Large hot air escape hole in bottom behind wing with exit deflector.
Total flying weight - 53.4 oz.
Motor - Exceed Rocket 2820-860
Prop - APC 11x5.5 Pusher
Battery - GensAce 3300 mAh
ESP - Castle Phoenix 45 in Governor mode
Timer - Will Hubin FM7 with remote start button and remote RPM adjustment
Tom Morris ball joint control system
Lines - 60' eye to eye
Lap time - 5.3 seconds
Flight time - 5:30
Ron Heckler
New York Control Line Stunt Team
« Last Edit: June 17, 2012, 11:29:52 AM by Ron Heckler »
Offline Andrew Borgogna
  • Andy
« Reply #115 on: June 17, 2012, 02:17:37 PM »
Plane:  RSM version of the Tom Warden Continental modified for electric.
Motor:  Hacker A30-10XL
ESC:  ZTW 70amp all settings at default.
Timer:  KR Governor/Timer. Gain set to 5 @ 8100RPM
Battery:  Hobby People 3200MAh 4S 25C with Deans connectors.
Prop:  APC 12x6.5WEP
External battery disconnect per Brett's proposed rule change.
All up ready to fly weight 62.5 ounces.
Andrew B. Borgogna
« Reply #116 on: July 24, 2012, 09:27:31 PM »
I am delighted to report that I now have a setup:
July, 2012
Impact with wider fuselage, taller "canopy", and bigger horizontal tail, 65 oz.
Lines just shy of 70' maximum.
Plettenberg 20-16 motor
Castle Ice Lite 75 motor controller
Hubin FM-9 timer
Thunderpower TP2700-5SPP65 battery
Deans connectors, Spot On RC connector shells
APC F2B 13-4.5 backwards prop
Works a treat.
October, 2013
Impact with wider fuselage, taller "canopy", and bigger horizontal tail, 69 oz.
E-flite Power 32 motor
Hubin FM-9 timer
Thunderpower TP2700-5SPR45 or TP2700-5SPF70 battery
Cox-Resinger 11-5.5 Green backwards prop
Lots of sustainably harvested, artisanal vortex generators
Works even better.
« Last Edit: November 01, 2013, 02:40:02 AM by Howard Rush »
Offline Jason Greer
« Reply #117 on: August 05, 2012, 04:54:23 PM »
Geo-XLe
59" wing span
~700 sq in area
Scorpion SII 3026 710kv
Flightmax 5s 3000 mah 20c
Ice Lite 50 in Set RPM mode at 9625 RPM
Hubin FM-2a
APC 13x4.5 EP
53.5 ounces RTF
.015 lines at 70' center of handle to center of model
Lap time 5.55
Average power consumption is 1800 mah
« Last Edit: August 06, 2012, 10:04:26 PM by Jason Greer »
El Dorado, AR
AMA 518858
Offline Larry Renger
« Reply #118 on: August 31, 2012, 03:29:36 PM »
This is what I am using on a 165 sq.in. (including flaps) model.  That is about the size of an old style 1/2A stunter of the 60's through 80's. The thing flies great.
Current equipment is a Hacker A20-34 motor swinging a 6 x 5.5 APC prop at 12,500 rpm, an 850, 3S pack, a KR timer and 20 Amp speed control.  It flies fine on 42' of Powerline (Spectra).  The size and weight of the equipment are aimed at much smaller aircraft than the stuff Andy uses on his Baby Pathfinder.
Offline Leo Mehl
Arctic Fox enlarged by 5%
« Reply #119 on: September 27, 2012, 10:37:01 AM »
No pictures yet. This is only the proto type but shows promise.
500 square inch wing.  Longer fuselodge and top loading battery. E-Flight 25 motor  Castle lite ice 50 and hubin FM 9 timer programed for 9100 rpm-A bit fast  10X6 wooden prop
 Thunder Power 3300MAH 4 cell battery. Flight time with 20 second ramp up 6.30 minutes. A small pakage and had hard time getting arming harness in. My next one will have a little more room for this. Lap times about 4.8 a little fast for this old guy but manageable. Plane not yet ready for competition and will be building another this winter.
« Reply #120 on: September 30, 2012, 01:48:22 PM »
Leadouts on the wrong side.   That's alright as I know I fly backwards according to you old guys.   H^^
« Reply #121 on: September 30, 2012, 03:09:29 PM »
Guys,
As a reminder, this thread is for posting your set up and not for general comments.  Lets keep it that way.
Thank you.
Offline Leo Mehl
« Reply #122 on: September 30, 2012, 05:03:02 PM »
Its  OK chris doc means no harm LL~ LL~ LL~ LL~
Offline Larry Wong
« Reply #123 on: October 07, 2012, 09:44:17 PM »
Plane  American Pi &  Zealot =  PI-LOT LL~
55" W.S.
E-Flight 25
Hubin FM-9 Timer
Zippy 4 Cell 3000 mAh
APC  13x4.5 EP thin
Flight time 5.30 min.
RPM 9575
Battery used 2200-2300 mAh
Lap time 5.1
Larry
Offline Dave Denison
Re: List Your Set Up... "Cardinal 660"
« Reply #124 on: November 27, 2012, 06:28:36 PM »
Cardinal 660 (my own design)
Wing Area   = 660sq.”
Wt. RTF (including battery)  =59oz.
Monokote  covered.
Motor =  E-Flite 25
Battery=  4 cell 3000,  40c
Launch RPM = 9655
Prop    =  APC 12x6 pusher
Lines =    64’ .018
Lap Time  =  5.2
Timer =  KR, set @ 5 on governor
ESC  =   Ice Lite 50
So far a great flying airplane, it now has aprox.70 flights.  A special thanks to Bruce Hunt for his outstanding trim flights
Regards.
Dave.
Ama 41041
ama 41041
Online Tim Wescott
« Reply #125 on: January 08, 2013, 09:35:10 AM »
Reniger ET-1.  These were for Christmas presents, to kids that needed everything.  I'm including prices for the skeptical:
Turnigy 2S 3S Balance Charger. Direct 110/240v Input (USA Warehouse), TGY-3/24289 = $11.34
ZIPPY Flightmax 800mAh 3S1P 20C (USA Warehouse), Z8003S20C/18636  = $8.00
Hobbyking SS Series 18-20A ESC (USA Warehouse), HK-SS20A/17793  = $7.18
2205C 1400Kv Brushless motor (USA Warehouse), 2205C-1400/26482 = $9.29
Hobby King GT-2 2.4Ghz 2Ch Tx & Rx (USA Warehouse), HK-GT2/15141 = $19.69
That works out to $55.50 with one battery, $63.50 with two.
« Reply #126 on: January 23, 2013, 02:55:58 PM »
 FinessE  (my own design)
W.Span:    58.25
W. Area:    651 sq. in.
Weight  :    59.5 oz.(RTF)
Mtr.      :  E-Flite 25
Batt.     :    4s  3000 lipos
ESC       :  Aerlion 50
Timer     :  KR
RPM       :   9600 approx.
Prop       :  APC 12x6 pusher
Lines      :   64 ft. eye to eye
Lap time :   5.2
  Has only 12 flights as of now, still making subtle adjustments.  Great line tension in overheads !!.....having fun!
 Regards.
 Dave.
ama41041
« Last Edit: March 08, 2013, 04:36:43 PM by Dave Denison »
ama 41041
« Reply #127 on: March 06, 2013, 08:23:54 AM »
Airplane
Max Bee Two (A derivate of  Igor Burger’s Max Bee 2011/12)
T/O weight: 65 oz or 1’842 Grams
Area (wing & flaps): 691 sq.in or 44.6 dm2
Airfoil: Trivial Pursuit with nose radius 5/16“or 8 mm d max = 2.44 in or 62 mm
Turbulators (4): at 10% of mid wing chord, parallel to LE. 0.02 x 5/16 in zig-zag 20in long
Empennage: Crossfire Extreme
Stabilizer A.o.A.:   +/- 0°
Motor thrust angle: + 1°
Motor axis above wing c.l.: 1.4 in or 36 mm
Stabilizer c.l. above wing c.l.:    1 in. or  26 mm
Roll trim: outside tab
Rudder: Adjustable
Lines: 0.015 (0.38 mm) x 64 ft or 19.5 m (eye-eye)
Power Train
Motor: AXI 2826/12  760 KV with cooling fan COOL1
ESC:   Castle Creations Phoenix ICE lite 75 A  Firmw. V 4.02, & Castle Link V3.55.00
Mode: Control Line / Brake on, high governing mode, Auto-Lipo off (for anti spark plug), Cutoff set to 15.0 V
Timer: Will Hubin FM-9
Programmer: Will Hubin FM-9 Programmer Version 2011, with New Phoenix High Gov. Mode.
Battery: Thunder Power Pro Power  G6 5S1P 2’700 mAh 65C  12.7 oz or 370 Grams
Spark protection:   Jeti 4 mm female on  + of all batteries. – battery with 5.5 mm female
Propeller: APC 13 x 5.5 EP (Thin electric pusher)
Power Train Setup
RPM:   9'553 RPM
Speed: Laptime 5.35 sec on lines: 0.015 (0.38 mm) x 64ft or 19.5 m (eye-eye)
Motor start delay: 30"
Flight time set on Hubin programmer: 5’30“
Time elapsed at end of roll-out (from depressing START button): 6:25
No wind battery recharge: 2'030 mAh (74%)
Final Flight Trim Setup
C.G.:   7.8 in or 199 mm. from hingeline forward (approx. 14.5% MAC)
Leadout centre:   1.42in or 36 mm. rear of C.G.
Tip weight:   Outer tip 1.48oz or 42 Grams heavier
Flaps / Elevators throw ratio:   1:0.8
Hinge seal:   None
Nose trim weight:   0
Tail trim weight: 0
Roll trim tab: 3° up
Rudder: neutral
Flight Trimming Process
April 2013: Insufficient tracking quality (wandering off from initial height) both in level and inverted flight.
June 2013; Trying to improve the quality of tracking in level and inverted flight, the following modifications (one by one but not necessarily in this order) have been done:
C.G. forward to 7.9 in (201 mm) from hinge line
Lead out center 1.67 in (43 mm) behind C.G.
Flat plate flaps TE rounded (was sharp edged)
Needle sharp elevator TE rounded
Replaced Max Bee empennage by the empennage of Crossfire Extreme, installed at +/0° AoA
Motor thrust axis set to +/-0°
Replaced Rabe rudder by an adjustable one
July 6th 2013: Still suffering from altitude hold issue in inverted flight (no wind).
July 27th 2103:
Added 20 in long zig-zag turbulators at 35% of wing chord.
Changed flap-elevator throw ratio to 1:0.8
Set motor thrust axis to +1° for pusher.
C.G. at 199 mm (7.8 in) from hingeline.
Leadout center at 151 mm (5.9 in) from hingeline, 1.6 in rear of C.G.
Outer tip 52 Gr (1.8oz) heavier than inboard tip.
Tracking improved, better level than inverted. Setup list updated.
August 6th 2013:
Removed turbulators at 35% of wing chord
Added turbulators at 1/2 in from stab leading edge
Tracking not as good as with turbulators at 35% of wing chord
August 10th 2013
Removed turbulators from stab
Added 20 in long zig-zag turbulators at 10% of mid wing chord, paralell to leading edge
Removed flap hinge seal
Removed 10 Gr / 1/3 oz tip weight
Lead out centre 1/4 in / 6 mm fwd.
Tracking ok, better than with turbulators at 35% of wing chord. Set-up list above updated
Peter Germann
« Last Edit: August 11, 2013, 04:07:25 AM by Peter Germann »
Peter Germann
Offline john_sabini
« Reply #128 on: March 16, 2013, 07:08:36 PM »
Eflite-Power 25
Castle 50 ESC
FM-9
4S 2700mAh
APC 11x5.5P
« Reply #129 on: April 10, 2013, 09:58:02 AM »
Plane:    "32" (own design..I now just number my designs)
Span:   61"
Weight:  65 oz.
Motor:  AXI 2826/12
ESC:   Phoenix ICE LIGHT 50
Timer:  KR
Battery:  Zippy Compact 5S- 3300
Prop:   APC 12-6 reverse rot.
Lines:  66.5'  0.018
High-mounted wing with anhedral..fits battery under wing at CG.
Floyd Carter
Eugene, OR
Offline John Rist
576 Ringmaster
« Reply #130 on: April 12, 2013, 02:23:56 PM »
Specifications are as follows:
Airplane: 576 Ringmaster by Dee Rice and Pat Johnston.
Wing area 576
Weight ready to launch 47 oz
Electric conversion kit by Walter Umland
Motor mount by Bob Hunt (G-10 hard noise)
Motor Cobra 2820/12 KV= 970
Speed Controller eBay special 60 amp compatible with Turnigy Programming card.
Timer KR with RPMs set at 9200.
Prop APC 12 x 6 EP
Static amp draw = 32 amps.
Battery Turnigy Nano-Tec 4 cell 2650 mah
62" lines. 5.5 sec lap time.
John Rist
AMA 56277
« Reply #131 on: May 18, 2013, 11:00:00 PM »
SHARK 45.  Built from the original plans.
Weight : 60.5 oz.(RTF)
Motor. : E-Flite 32
Batt. : 5s 25c Zippy 2700 lipos
ESC : Saker 45        Timer : KR
RPM : 8600 approx.
Prop : APC 12x6 F2B pusher
Lap time : 5.2        Finish :Monokote
One of the best airplanes I’ve had, very smooth and grooves well.
ama 41041
Offline Ron Heckler
« Reply #132 on: May 21, 2013, 10:26:04 PM »
My own design using Bob Hunt's "Caprice" foam wing and moments
Wing Span = 51" (equal panels)
ESP = ICE 50
Motor = Exceed Rocket 3020-860
Timer = Will Hubin FM2a with remote RPM pot and Start Button
Controls = Tom Morris System
Prop = 11x5.5 electric pusher
Lines = 60' eye to eye
Flying Weight = 54 oz.
Lap time = 5.3 sec
Covering = Ultracote
Offline Duke.Johnson
Re: Pat King electric Ringmaster 150
« Reply #133 on: July 25, 2013, 10:35:20 PM »
I built this electric Ringmaster 150 from one of Pat King's (patdk@aol.com) laser cut kits.
Pat's kit comes with plans for either IC engine or an electric motor power.
Motor = Turnigy  C2826 1350 KV (from  hobbyking.com)
ESC = Castle Creations Phoenix 25 Amp
Timer = Will Hubin FM9 (whubin@kent.edu)
Prop = APC light Electric 7 x 5 pusher
Battery = 3 cell 750 mah (Rhino brand from hobbyking.com)
Flight ready weight = 8.9 oz
John - what size lines?
Offline Dan Bregar
  • Field Marshall
e-Pathfinder (Polyspan & Randolph dope)
« Reply #134 on: July 27, 2013, 02:30:12 PM »
Wing span 55"
Wing area 620 sq. in.
Weight 55 oz.
Mtr. Cobra 2826/10 (rear mounted)
ESC-Phoenix 45  Governor High mode
Timer-Hubin FM-9
Batt. Turnigy nano-tech 4S3300
Prop-APC 13x4.5EP cut to 12" dia.
Lines-63 ft. eye to eye, .015 dia.
Lap time-5.2 sec. (mtr. RPM 9600)
Uses about 2200 mah per flight
Set-Up has done well on the contest circuit
« Last Edit: September 30, 2014, 12:58:49 PM by Dan Bregar »
AMA 33676
Re: Profile Scale B-29
« Reply #135 on: July 27, 2013, 07:23:15 PM »
This model was scratch built from my own plans for CL Profile scale event
96" span
72" long
850 Square inches, wing area
E-Flite E-25 brushless outrunner electric motors
Hobby Lobby E-RC 45 amp speed controls
Hobby King Zippy 4S batteries, 3000 Mah
13 lbs ready to fly
Foam wing with balsa skins
1/16 balsa fuselage sides with stick structure underneath skins
Fiberglass and Lustre Kote aluminum paint
Throttle control is done with 2.4 Ghz, Tactic 650 transmitter and TR624 reciever
The #4 motor has the BEC active and powers the receiver that is housed in the fuselage
The #1, #2 and #3 motors have the BEC deactivated
Model flies on 60 foot lines with a traditional stunt handle, the 2.4 Ghz transmitter hangs on my hip and controls the throttle
This model was first flown in June of 2013 and took 1st place at the 2013 Nationals in Muncie in CL Profile Scale
Fred Cronenwett
Manchester, MO
Fred Cronenwett
Offline 55chevr
« Reply #136 on: August 11, 2013, 07:12:19 PM »
This model is a bastardized Forerunner design scratch built up fuselage and a Sig Mustang Stunter wing.  Fuse has 1/2" added to nose to accommodate battery and 1-1/16" added to tail moment to keep proportions to Forerunner design.  Tail is scratch built to Forerunner plans with elevator/stab tips modified to resemble wing tips.
Span = 50"
Wing Area = 480 sq. in.
Weight = 57 oz
ESC = Castle Creation Phoenix Ice Lite 50
Batteries = 3000 4S
Timer = Hubin FM9
Prop = 11 x 5.5 Pusher
Joe Daly
Offline linheart smith
Cavalier, Profile
« Reply #137 on: August 24, 2013, 12:25:46 PM »
52 inch wingspan
Built up fully sheeted wing
Everything covered with .2oz carbon
40 oz < battery
48 oz ready to fly
APC thin electric 11-5.5 pusher prop                      Dennis Adamisin  dadamisin@yahoo.com
Motor E-Flite Power 15                                         Bob Hunt might have these or Amazon.com
ESC   Phoenix ICE 50 lite                                      I buy these on Amazon.com
Timer  Hubin FM9                                                 Direct from Will Hubin   whubin@kent.edu
Safety switch  Maxx Products 6970                        I buy these on Amazon.com
Battery Hyperion 4S CXG3 25C  2500ma               Tom Morris supplied this to me.
Flying on 62 foot .015 eyelet to eyelet  (Thinking about cutting to 60 feet.)
Timer set for 5:17 flight time
Using <1800 amps
« Last Edit: August 28, 2013, 04:56:33 PM by linheart smith »
linheart
Offline Larry Wong
« Reply #138 on: August 30, 2013, 04:32:18 PM »
Crossfire
E-Flight 25
ESC  Phoenix 45
timer Hubin FM-9
Prop. APC  12x6 EP
True-turn Turbo spinner
Bob Hunt front mount
Battery  4c 14.8v   zippy 3000 mAh
65' lines
8975 RPM
Flight time  5 1/2 min.
lap time     5.2
AS of now
E-Flight 32
Battery Thunder Power 2250mAh 5cell 45c and 2700mAh 5cell 25c
10650 RPM
3 blade  Cox & Resinger Pusher 11x5.5 (green)
« Last Edit: November 15, 2013, 03:51:49 PM by Larry Wong »
Larry
Offline 55chevr
« Reply #139 on: September 15, 2013, 11:48:19 AM »
Pat King Ringmaster Trainer IIE
Arrowind 2815/09
Castle Creations Ice Lite 50 ESC
Hubin FM-9 Timer
4S 2200 battery
9 x 6 EP prop
RPM setting 10,000
60' x .018 lines
1.2 oz wing weight
Really docile trainer for new flyer.  Builds in a few hours.  I left it clear to make repairs easier but it is robust.
Joe
Joe Daly
Offline 55chevr
Re: List Your Set Up... Nobler ARF
« Reply #140 on: October 15, 2013, 08:02:07 PM »
Flew it first time this weekend.
Top Flite ARF Nobler;
Tom Morris controls
Exceed Rocket 3015
Castle Creations Phoenix Edge 50 ESC
Hubin FM-9 timer
4S 2200 Battery
10x4.8 APC ER pusher prop
RPM setting 10,156
60' x .015" lines
Needs a little more trim.  Only 4 flights on it under fairly windy conditions but flies like I remember my old green box Nobler did in 1960.
Joe
Joe Daly
Offline 55chevr
Re: List Your Set Up... Forerunner Gen2 Electric
« Reply #141 on: October 19, 2013, 01:37:18 PM »
Forerunner Gen2
Built from Custom Models kit plans
1/2" added to nose
Built up profile fuselage
Built up empennage
Bob Hunt triple cored wing
Tom Morris controls
Scorpian SII 3020-890 motor
3300 4S Lipo
Castle Creations Edge Lite 50 ESC
Hubin FM-9 timer
APC 11 x 5.5 EP
RPM setting 10200
Joe Daly
« Reply #142 on: October 21, 2013, 03:16:54 AM »
A shortcut for absolute beginners and aerobatics practice:
Airplane   Gee Bee 1000 R/C 3-D Kit, EPP, modified
Span    39.3 in (1000 mm)
Landing gear    3 ½ in (90 mm) fwd. (for grass ops)
Weight   29.5 oz (835 Gr.)
Elevator throw    +/- 35°
Flaps throw      +/- 20°
C.G.     2.4 in (60 mm) from wing l.e.
Leadout center   3.34 in (85 mm) from wing l.e.
Lines   0.012 in x 49 ft   (0.3 mm x 15 m)
Motor     2214/1400    1’400 RPM/Volt   14 poles
Propeller   APC 10 x 5.8 EP  F2B
ESC    Castle Phoenix Edge Lite 50 A
ESC Mode   Control Line, Governor high
Timer   Hubin FM-9
Battery   2’200 mAh 3S
Beginner setup   Take-off from ground and level flight only
Handle spacing   3 in  (75 mm)
RPM   7’300
Speed   7.5 sec / lap
Duration   1:00 min
Number of flights   8 per one full charge
F2B practice setup   All manoeuvres
RPM   9’624
Speed   5.0 sec / lap
Duration   4:00 min (max.)
Consumption   1’850 mAh (85%)
Number of flights   1 per one full charge
Remark: Do not flyin wind.
Peter Germann
« Last Edit: October 22, 2013, 05:07:28 AM by Peter Germann »
Peter Germann
Online Fred Underwood
Re: List Your Set Up... Genesis 2013
« Reply #143 on: November 15, 2013, 02:43:18 PM »
Wing span:  59”  Area: 665
Weight: 65 oz
Motor: E-flite 32
ESC:  ZTW 50 amp
Governor/timer:  KR
Battery:  Zippy Compact 5S 2700
Prop:  12X6 F2B
Lines: 65’
Lap time: 5.25
RPM:  8800  Gain 6
Battery usage:  2000 ma
Fred
352575
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
Legacy - Brodak
« Reply #144 on: January 31, 2014, 10:37:06 AM »
Legacy Brodak
Wing span: 59”
Area: 687
Weight: 70 oz
Motor: Hextronik 4250 - 650kV  - 1250W
ESC:  Castle ICE 50
Timer:  C/L Timer by Fiorotti  - www.metaenergia.com.br
Battery:  AsPec Turnigy  5S - 2200mA - 65C
Prop:  13X5 - 3 blade - JXF
Lines: 64 ft
Lap time: 6.0
RPM:  8300 flat / 9200 stunt
Battery usage:  1900 ma
Flight time: 5 min.
Rogerio Fiorotti
« Last Edit: January 31, 2014, 04:54:20 PM by Rogerio Fiorotti »
« Reply #145 on: January 31, 2014, 01:11:59 PM »
Thanks for posting the video and your set up.  H^^
Just a bit curious what 13x5 3-blade you're using?
« Reply #146 on: January 31, 2014, 04:58:50 PM »
Dear Joe
I'm using the propeller JXF, but switched to 13X6.5 Carbon where I got better results.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=25693
Rogerio Fiorotti
« Reply #147 on: February 13, 2014, 06:21:17 AM »
Airplane: Fireshark II (modif)
T/O weight: 67.3 oz or 1’910 Grams
Area (Wing & flaps): 694 sq.in or 44.7 dm2
Wing airfoil: NACA 0018 modif. max. 2.32 in or 59 mm.  8 mm (5/16") flatplate flaps
Empennage airfoil: NACA 0012  max. 0.8 in or 20 mm. Elevators integrated
Motor thrust axis, vertical: +/- 0°
Motor axis above wing c.l.: 0.8 in or 20 mm
Stabilizer c.l. above wing c.l.:    1.8 in. or 45 mm
Rudder: Neutral, not adjuststable
Power Train
Motor: AXI 2826/12  760 Kv with cooling fan COOL1
ESC:   Castle Creations Phoenix Edge lite 75 A  Firmware V 4.19 (Beta)
Mode: Control Line / brake on 90%, high governing mode, auto-lipo off. Cutoff set to 15.0V
Timer: Hubin FM-9
Battery: Thunder Power Pro Force G8 2’700 mAh 5S 70C
Spark protection:    Jeti 4 mm female on + of batteries.
Propeller: APC 13 x 5.5 EP (Pusher)
Flight Setup & Trim, 17°C, calm
Date: October 2015
C.G.:   7.2 in or 183 mm from hingeline fwd.
Leadout Center: 1.26 in or 32 mm. rear of C.G.  5.9 in or 151 mm from hingeline fwd.
Tip weight:   Outer tip 1.2 oz or 34 Grams heavier
Elevators / Flaps throw: +/- 45° / +/- 45°
Elevator trim: none
Hinge seal: none
Nose trim weight:   0
Tail trim weight: 0
Lines: 0.015” x 64 ft or 19.5 m (eye-eye)
Delay: 30 sec
RPM set: 9'154
Max controller temp. logged: 63 °C
Laptime: 5.3 sec
Motor runtime set: 5’15“
Battery recharge: 2'050 mAh
« Last Edit: October 29, 2015, 05:06:29 AM by Peter Germann »
Peter Germann
Offline Keith Miller
« Reply #148 on: February 14, 2014, 08:01:21 PM »
Airplane:   Misfit (kit-bashed Tower Uproar)
T/O weight: 58 oz
Area (Wing & flaps): 651 sq.in
Wing loading: 12.9 oz/sq ft
Power Train
Motor: Arrowind 2832-05 960 kV
ESC:   Castle Creations Phoenix Ice Lite 75 A  Firmware V V 3.27
Mode   Control Line, high governing mode, brake disabled
Timer: Hubin FM-9
Battery LiPo: Zippy 2700 mah 25C 4cell
Propeller: APC 12x6 EP (Pusher)
Lines: 0.018” x 60 ft
RPM:   9092 set on Hubin; 9155 measured in air (data logger)
Laptime:     5.2 sec
Motor runtime set:     3'0" (trim flights)
Peak current logged: 33.1A
Consumption 1.24 Ah over 3 min (~413 mAh/min)
Expect 5 min flights to use 77% capacity of 2700 mAh packs
** Edit **
2700 mAh packs can only run 4 minutes max.  Went to 5 cell 3700 mAh; 5 minutes leaves the packs at 40%, 3.82v/cell.
« Last Edit: June 22, 2014, 08:22:58 AM by Keith Miller »
« Reply #149 on: March 30, 2014, 09:55:43 AM »
Airplane:   Patrouille Suisse-1 E (a Cardinal ’92 derivate)
Built :           December 2000 for Jet .61 on pipe. T/O weight with 3/4 fuel 70 oz or 1’985Gr
Converted to E:   March 2014
T/O weight:     69 oz or 1’959 Grams
Area (Wing & flaps):    Cardinal ’92
Wing airfoil:     Cardinal ’92, blunt nose modif.
Empennage airfoil:   Cardinal ’92
Motor thrust angle:   +/- 0°
Motor axis above wing c.l.:   Cardinal ’92
Stabilizer c.l. above wing c.l.:   Cardinal ’92
Power Train
ESC:   Castle Creations Phoenix ICE lite 75 A  Firmware V 4.19 (Beta)
Mode:   Control Line / brake on, high governing mode, auto-lipo off. Cutoff set to 15.0V
Timer:   Hubin FM-9
Programmer: Hubin in Phoenix New High Mode
Battery LiPo:   Thunder Power Pro Force G8 2’700 mAh 5S 70C
Trim
C.G.:   7.6 in or 192 mm from hingeline fwd
Leadout Center:   1.57 in or 40 mm. rear of C.G.
Tip weight:   Outer tip 2 oz or 55 Grams heavier
Elevators / Flaps throw:   40° / 40°
Hinge seal:   Flaps
Nose trim weight:   0
Tail trim weight:   0
Battery trim posistion:   Middle
Lines:   0.38 mm (0.015 in) x 19.5 m (64 ft) (Eye-eye)
RPM:   9'216 RPM
Laptime:   5.4 sec
Motor runtime set:   5’30“
Battery idle voltage after ldg.:   18.66 V or 3.73 V/cell (w/o load, battery has 45 cycles)
Battery re-charge:   2’000 mAh
March 30 2014   Peter Germann
Peter Germann
