  • June 23, 2025, 04:51:46 AM
Author Topic: AP .061 and .09  (Read 943 times)
Offline jim gilmore
AP .061 and .09
« on: March 03, 2009, 11:19:59 PM »
Is there a needle valve and spraybar along with a venturi that could be used to make there true c/l engines ?
Offline ray copeland
Re: AP .061 and .09
« Reply #1 on: March 04, 2009, 06:22:16 AM »
Jim, i have had a .061 apart on my desk looking at it for about a week now trying to figure the best way to get rid of the supplied carb set-up. The holes in the casting where the venturi mounts are too close to the top to drill any larger to fit a needle valve. I may go with making my own venturi out of nylon to accept a straight bolt thru these holes and then use a Larry Driskil needle valve above. So far, that's my best solution, tho i do run one other wasp with the throttle wired open and it flies okay, just seems hard to get the right needle setting and hold it for a 5 minute flight.. on the other hand it may just need more breaking in, that motor was very tight when brand new and very hard to get started the first couple of times.   Ray
Offline jim gilmore
Re: AP .061 and .09
« Reply #2 on: March 06, 2009, 07:50:59 PM »
After a lot of loking I founf this. http://www.globalhobby.com/public/gallery/212700.asp
Looks nliken there is a drop in replacment carb/venturi that is no throttle to make the AP 09/15's c/l ready. zbut I do not see why we cannot just get a venturi madew and use another needle valve assy like maybe from an enya or os max .09 ?
Offline L0U CRANE
Re: AP .061 and .09
« Reply #3 on: March 11, 2009, 01:58:47 PM »
Jim,
Price and availability may answer your thought. Sure, you can have one made, otherwise.
I'd be interested to hear the availabilty and price from Global. Probably still need the tuna can muffler and pressure tap... The choke on the carb versions is pretty big; expect same for the CL venturii and stub sprinkler NVA.
\BEST\LOU
