  • July 07, 2025, 09:00:10 PM
Author Topic: Secret exposed! Pen Lines. Photos Added!!  (Read 4556 times)
« on: August 08, 2014, 09:44:07 AM »
Oh those pen lines.
I wanted to take a casual approach, an easy and quick way actually, to applying pen lines to my no longer Super Ringmaster. Now a P-40.
Didn't want to go overboard, I don't go out on boats because of a fear of being thrown overboard  n~,
Anyway, I drew this template up and made tiny holes at each intersection of the lines. Stabilo for marking placement dots. Just flip it for the other wing panel.
Thought it would be easier than using a measurement system directly on the wing.
Betcha lots of guys do it this way.  ;D
Maybe not?
Edited for SP.
« Last Edit: August 09, 2014, 04:18:00 PM by Avaiojet »
« Reply #1 on: August 09, 2014, 04:17:11 PM »
Nope, I do it the hard way, but may adopt this method. Looks simpler. Just enough accurate and realistic lines can add to a model, but too many that make no sense ruin it to me.  Thanks for this tip. H^^
Ty,
I've never seen anyone present a photo of or mention a template. I'm sure it's a secret.  S?P
You see double lines on my template only because of the layout time, quicker this way with my program.
The finished product has a single line representation. You can tell by the holes.
I found the correct P-40 layout on line. Correct?  Reasonably correct, but not really for the shape of a Ringmaster wing.
First model I ever drew pen lines on, still only took less than an hour to do all the bottom for what you see in these photos. Moving the ruler around because of wet ink takes up time. Go back to the area you left when the ink dries.
Here's the pen. Dries impervious to water, even hard rubbing.
Works for me.
Thanks for the reply.
Offline RC Storick
Re: Secret exposed! Pen Lines. Photos Added!!
« Reply #2 on: August 09, 2014, 05:35:00 PM »
I hope you tested this pen with clear before going to all this work. Clear tends to make some puns smear,run or blur. Let us know. But it does look good.
« Reply #3 on: August 10, 2014, 06:01:08 PM »
Good puns never smear...  LL~ Steve
« Reply #4 on: August 10, 2014, 06:08:00 PM »
Steve,
I don't think it's so much the puns, but the ink that's in them.
Offline RC Storick
« Reply #5 on: August 10, 2014, 06:50:31 PM »
good luck
« Reply #6 on: September 03, 2014, 02:53:15 PM »
Just thought I'd update the Thread, pen lines on the top of the model.
Did the layout the same way, with one pattern, then flip it for the other wing or stab.
BTW. The elevator and aileron stuff is vinyl.
Fuselage will be last.
