Tim, Igor,
The experience has taught me that when I start digging deep enough the "things" usually complicate instead of getting simpler but it is ok with me.
Igor,
You wrote:"So also Cobra pumps air". How? If I take my Cobra 2826/12 and run it without propeller at safe static RPM., say 5,000... Will this motor pump the air? Will I be able to feel the directional air flow through the motor along the shaft axis? Please note directional. The rotating parts will disturb the air inside the motor and there will be some air movement around the motor due to thermal convection but I doubt this movement will be directional along the shaft axis. I can lit a cigarette (I do not smoke but will this time), blow the smoke into the plastic bag, let it cool to ambient temperature to avoid the additional convection and release it slowly around the running motor to see what is happening.
Copper losses v/s iron losses and efficiency? I have to read more about it as this is extremely interesting.
I have received the photo of your heat sink for AXI in the rear mount configuration from Keith R. and immediately asked myself the question: will this heat sink work efficiently when the motor is front mounted? The answer is rather not.
Because I am going to front mount all the motors in my future planes, I am looking for the best cooling solution for this type of mount.
Tim,
You wrote: "I would love to see someone do some experiments with airflow vs motor heat, with various combinations of airflow from fans and ram airflow. But it's a heck of a lot of work for no material gain, and there seems to be a lot of successful electric stunters out there."
If I manage to do this what I am planning to do, I will publish on this forum the results of my tests. I will do it only if the results are numerical and will make all the details available for the C/L community. Peter German (SUI) does always the same and I truly appreciate his "community spirit".
"Learning never stops and when it stops this means you are dead".
Going flying with my eParrot now. By the way: I made a little inlet for the air to cool the ESC and the ESC heat sink temperature immediately after 5 min. pattern flight in 20 deg. C ambient temperature dropped from 45 to 29 deg.C.
Matt
