stunthanger.com
Welcome, Guest. Please login or register. May 25, 2017, 04:12:44 AM
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Sakitumi-E  (Read 1285 times)
Trade Count: (0)
Admiral
Offline Offline
« on: April 06, 2017, 07:31:27 PM »
I have started my Sakitumi-E.  The wing and elevator are ready to be covered.  I am waiting on some 1/32 plywood to skin the fuselage for stiffness. I should be able to remove wood from the core of the fuselage to keep the weight the same.
I do have one question.  Should I offset the rudder any at all?
Logged
john e. holliday
2017
Trade Count: (0)
Admiral
Offline Offline
« Reply #1 on: April 06, 2017, 08:51:41 PM »
Follow the plan or go to Walters site and look at construction photos. Devil
Logged
I was always taught to respect my elders, but it keeps getting harder to find one.
Today I broke my personal record for most consecutive days lived.
AMA 23530
Trade Count: (0)
Admiral
Offline Offline
« Reply #2 on: April 06, 2017, 10:07:20 PM »
Unless I am blind the plans don't show that view of the rudder.  Walter's build log don't cover it either.  Pictures of his finished model aren't totally clear either.  It appears that their may be some offset but not sure.  I am guessing that some offset would be OK.
Logged
Chris Behm
C/L Newbie
2016 supporter
Trade Count: (0)
Admiral
Offline Offline
« Reply #3 on: April 06, 2017, 11:51:15 PM »
Normally the rule is to put in just a barely perceptible amount of rudder offset, so that it isn't offset the other way, if trying to set it centered.
They say too much offset makes for poor line tension in the overheads....
Logged
Chris
AMA 5956
2008 F3F USA Viking Race Team
badbill
Trade Count: (0)
Commander
Online Online
« Reply #4 on: April 07, 2017, 04:02:58 AM »
I didn't use any offset, and couldn't be happier with the way mine flies.
Logged
Bill Davenport
AMA 28141
Trade Count: (0)
Admiral
Offline Offline
« Reply #5 on: April 13, 2017, 08:41:49 AM »
In order to stiffen the fuselage I glued 1/32 plywood on either side.  To keep the weight down I drilled holes in the original fuselage.  I used Tightbond glue and weights to glue the sides on.  I also installed a fiberglass motor mount that is laminated to the plywood motor mount ring that came with the kit.  The finisher fuselage weighs 8.4 oz and is stiff as a base ball bat.  Beings it is now plywood all over it will take very little paint to make it look good.
Logged
Trade Count: (0)
Admiral
Offline Offline
« Reply #6 on: April 17, 2017, 09:19:15 AM »
Spinners for an electric setup, for me,  has always been a pain in the rear.  Huh   I use pusher props and have had to cut out the slots for the LH prop (ugly).  You can buy LH spinners but they are $$$$$. Spinners also add rotating mass which is not a good thing.
So I came up with the idea to make a round disk with holes in it for cooling.  Fashion a noise block to round out the noise.  once all painted black I think it will look good and work well.
Logged
Avaiojet
2017
Trade Count: (0)
Admiral
Offline Offline
« Reply #7 on: April 17, 2017, 09:30:13 AM »
John,
WOW!
Nice workmanship!  Hoff
Nice build and great holes.
I'll be looking!
CB
Logged
"Nothing is easier or more pathetic than being a Critic."  Donald Trumph, 5-13-17.
I look at the Forum as a place to contribute and make friends, some view it as a Realm where they could be King."
Owner of CFC Graphics. "Model Airplane Graphics from a Model Airplane Builder."
"I'd like to build a reputation, not be given one."
X-Files quote
"Ya gotta love it when a plane comes together."
Proverb 11.9  "With his mouth the Godless destroys his neighbor..."
"So popular, they named a television series after me."
"Perhaps the greatest challenge in modeling is to build a competitive control line stunter that looks like a real airplane."
David McCellan, 1980.
"If you can't rise above, you destroy."
Rush Limbaugh, 2015.
Trade Count: (0)
Admiral
Offline Offline
« Reply #8 on: April 18, 2017, 12:48:08 PM »
Making sure tail feathers are square in every direction.  y1
Logged
Trade Count: (0)
Admiral
Offline Offline
« Reply #9 on: April 18, 2017, 07:24:25 PM »
Vertical all squire with just enough outward offset to insure it's not in.
« Last Edit: April 18, 2017, 10:03:03 PM by John Rist » Logged
Trade Count: (0)
Admiral
Offline Offline
« Reply #10 on: April 19, 2017, 04:37:16 PM »
Temporally assembled to see what it looks like.  I am just realizing this is a big airplane.  It should fly great!
Logged
Avaiojet
2017
Trade Count: (0)
Admiral
Offline Offline
« Reply #11 on: April 19, 2017, 05:22:36 PM »
John,
Looking really good.  Hoff
I made Sakitumi lettering for someone can't remember who?
Send me a PM or e-mail with your address and color, size, and I'll get some Sakitumi lettering out to you.
CB
Logged
X-Files quote
john e. holliday
2017
Trade Count: (0)
Admiral
Offline Offline
« Reply #12 on: April 20, 2017, 08:56:27 AM »
Looking good.  I watched Dan McEntee fly his in St Louis and it looked great.  Of course it was IC powered.
Logged
AMA 23530
Trade Count: (0)
Admiral
Offline Offline
« Reply #13 on: April 20, 2017, 04:57:20 PM »
John, do you by any chance know what Dan's Sakitumi weighs as a gasser?
Logged
badbill
Trade Count: (0)
Commander
Online Online
« Reply #14 on: April 21, 2017, 06:06:06 AM »
I haven't started on my nitro version yet, but my electric is 36.7 oz without the battery... Probably has 65-70 flights on it now. Still loving it!
Logged
Bill Davenport
AMA 28141
Trade Count: (0)
Admiral
Offline Offline
« Reply #15 on: April 21, 2017, 06:26:54 AM »
Thanks Bill.  I haven't  got a weight on mine yet but this gives me a target weight to work with.
Logged
john e. holliday
2017
Trade Count: (0)
Admiral
Offline Offline
« Reply #16 on: April 21, 2017, 11:21:39 AM »
Contact him, he is on here once in a while.
Logged
AMA 23530
badbill
Trade Count: (0)
Commander
Online Online
« Reply #17 on: April 21, 2017, 12:54:44 PM »
Just so you know, that was the weight with EVERYTHING, RTF but no lipo...
Logged
Bill Davenport
AMA 28141
Trade Count: (0)
Admiral
Offline Offline
« Reply #18 on: April 29, 2017, 06:52:21 PM »
Life sometimes gets in the way of the fun stuff.  It may be a few weeks before I get back to finishing this project.  Getting new carpet and laminate flooring in the house.  At my age I work slow so it will take time to get the house ready for the carpet layers.   Cry
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.21 | SMF © 2015, Simple Machines
Valid XHTML 1.0! Valid CSS! Dilber MC Theme by HarzeM
