Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
May 10, 2024, 06:24:25 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
Open Source ESC
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Open Source ESC (Read 2047 times)
Howard Rush
22 supporter
Trade Count:
0
Admiral
Open Source ESC
on:
June 01, 2017, 02:53:37 PM »
Anybody tried one of these?
http://www.ollinboardcompany.com/product/vedder-s-speed-controller
Logged
pmackenzie
Pat MacKenzie
24 supporter
Trade Count:
0
Captain
Re: Open Source ESC
Reply #1 on:
June 01, 2017, 06:22:38 PM »
Dug around a bit, and the firmware seems to be aimed at the powered skateboard market.
http://vedder.se/2015/01/vesc-open-source-esc/
No mention of governor mode for example. Some very different requirements for a wheeled vehicle ESC.
If you want to look at open source then look into Blheli. It is supported on many ESCs, and has governor mode.
Logged
MAAC 8177
Howard Rush
22 supporter
Trade Count:
0
Admiral
Re: Open Source ESC
Reply #2 on:
June 01, 2017, 09:35:31 PM »
Thanks, Pat.
Logged
Keith Renecle
Trade Count:
0
Captain
Re: Open Source ESC
Reply #3 on:
June 02, 2017, 08:50:33 AM »
Hi Pat,
I gather that BLHeli is the firmware? Would that be compatible with the Vedder esc?
Keith R
Logged
Keith R
pmackenzie
Pat MacKenzie
24 supporter
Trade Count:
0
Captain
Re: Open Source ESC
Reply #4 on:
June 02, 2017, 06:09:43 PM »
I don't know if the Vedder ESC is BLheli compatible, but I doubt it.
As far as I know only Atmel and Silabs processors are supported.
In any case it is way too expensive, the whole idea behind using BLheli is to get excellent firmware on inexpensive hardware.
I have not figured out what ESC would be good for testing in F2B. Lots of 40 amp controllers, but that does not leave a lot of headroom.
You have to go through the docs, and make note of the comments. Pretty sure you want one with fast switching, and capable of "damped light" mode.
The latter should allow for regenerative braking on downlines
Atmel ESCs:
https://github.com/bitdump/BLHeli/blob/master/Atmel/BLHeli%20supported%20Atmel%20ESCs.pdf
Silabs ESCs:
https://github.com/bitdump/BLHeli/blob/master/SiLabs/BLHeli%20supported%20SiLabs%20ESCs.pdf
Don't look at BlHeli_s - no governor mode.
Logged
MAAC 8177
Keith Renecle
Trade Count:
0
Captain
Re: Open Source ESC
Reply #5 on:
June 04, 2017, 07:58:55 AM »
Thanks Pat!
Logged
Keith R
Tim Wescott
2016 supporter
Trade Count:
0
Admiral
Re: Open Source ESC
Reply #6 on:
June 04, 2017, 01:38:23 PM »
Although, as an open-source ESC, someone could put a governor mode into it.
All of the features he's proud about putting into the thing are ones that would support speed governing that's both aggressive and smooth.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
Open Source ESC
