  • April 24, 2024, 01:30:57 PM
Author Topic: saito 40 Vector  (Read 189907 times)
Offline bruce finley
saito 40 Vector
« on: December 04, 2014, 06:37:44 AM »
So, finally got it done.  Not a beauty queen, just a crash repair with a major engine swap!!  Went from a aero tiger .36, to a Bob Reeves Saito set up with the venturi work done by Jim Lee at Lee Machine Shop(quick turnaround I might add.)  Have not had much time to fly due to work and weather but so far very, very promising.  Now flies like it has a Aero Tiger .51 installed--if such a thing existed--pulls through wind like crazy, just had me giggling.  Anyway, very happy so far, will report more as time goes on.
I know everybody likes pictures....... H^^
Kind of built the thing in the air due to the nature of the repair.
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: saito 40 Vector
« Reply #1 on: December 04, 2014, 08:54:14 AM »
Fantastic, looks great..
It is pretty amazing just how much "Stunt" power that little Saito will deliver when operated the way it likes to be ran.
Re: saito 40 Vector
« Reply #2 on: December 04, 2014, 11:21:09 AM »
Thanks to Bob Reeves for blazing the way on this setup for these Saito motors.
http://www.tulsacl.com/SaitoCarb.html   D>K
Online Dennis Adamisin
Re: saito 40 Vector
« Reply #3 on: December 05, 2014, 07:15:16 AM »
Wow GREAT job in the conversion!  That side mount came out looking squeaky clean.
Great idea on the power too.  Anyone who has seen Bob Reeve's Saito's perform know that he is on top of that game.
Re: saito 40 Vector
« Reply #4 on: December 05, 2014, 08:01:15 AM »
Thank you!  On the center section repair on wing, used polyspan to strengthen(realise this was an arf), finished the repair areas with Rustoleum white topped with brushed on KBS clear.  Total weight ready to fly 49.5 oz.
Re: saito 40 Vector
« Reply #5 on: December 05, 2014, 07:02:33 PM »
Wait till you see how much power that 40A pumps out in the air.
Offline Bob Reeves
Re: saito 40 Vector
« Reply #6 on: December 06, 2014, 11:33:16 AM »
Already has...
Re: saito 40 Vector
« Reply #7 on: December 24, 2014, 11:05:15 PM »
 I like it, a little different look with the side mount too. Looks to me like this one might be worth stripping the monokote and doing a full refinish. y1
Re: saito 40 Vector
« Reply #8 on: December 27, 2014, 07:17:22 AM »
Thank you, but I don't think I'll be stripping this one.  Arfs have a place in our hobby, I just don't have a lot of respect for them.  I just use them as learning tools and test beds for engines or ideas, etc.  Arfs are great when you don't have time to build, I just prefer to build from kits or from scratch.  To do so is simply more fulfilling and gratifying for me.
I do enjoy the sidemount for ease of starting as I do not enjoy passing a "chain saw" running at full tilt from your helper to the ground.  Fact is, I might do all my mounts this way in the future, 2 stroke or 4 stroke.. :) :)
Re: saito 40 Vector
« Reply #9 on: December 30, 2014, 06:49:56 PM »
 Agreed. y1
Offline Richard Hutlet
Re: saito 40 Vector
« Reply #10 on: January 17, 2015, 10:39:16 AM »
I just asked about the Aero Tiger 36 in the engine set up forums ad I am building the Kit Vector 40
soon. This looks very interesting. Can that Saito 40 be used out of the box? Or are the modifications you
did pretty much mandatory for that combo. I am asking because up here sending an engine out for
that sort of work would take months.
Re: saito 40 Vector
« Reply #11 on: January 17, 2015, 10:42:27 AM »
NM. here I thought I was Grey...must be a lot of blond mixed in with it ~^
Converting an RC engine to C/L would take some mods  mw~
Re: saito 40 Vector
« Reply #12 on: January 18, 2015, 08:25:03 PM »
Send it out to Jim Lee for a Bob Reeves carb-go fly.
Offline Bob Reeves
Re: saito 40 Vector
« Reply #13 on: January 19, 2015, 01:23:25 AM »
The only thing the engine itself needs is proper break-in, follow the directions in the book that comes with the engine.
After break-in remove the carb and if you have access to a lathe modify it yourself or you can send it to Jim Lee. Jim will typically turn it around within days not weeks.
This link shows the carb mod for a 56/62/72 but the 40 is almost identical. Use a 10-32 nylon screw instead of 1/4-20 and follow the setup instructions at the end.
Re: saito 40 Vector
« Reply #14 on: January 23, 2015, 04:59:32 AM »
Not months, Jim was able to get it back quickly and that included some vacation time on his part.  Maybe three weeks total from ship out to getting the part back. :) :)
Re: saito 40 Vector
« Reply #15 on: February 06, 2015, 07:10:03 AM »
Oh well..........
Lost the Vector to a broken up line.  Engine came through with little damage.  Planning on taking my Brodak kit Cardinal profile and building a full fuse for it.  I just don't care for Profiles too much!! n1 n1
As I don't have an original Cardinal plan, I will just eyeball the profiles of what images and plans I can find on the net, keeping the same numbers as the profile plans.  Any body have a full fuse plan they can loan?
Thank you! Bruce
Offline Bob Reeves
Re: saito 40 Vector
« Reply #16 on: February 07, 2015, 03:48:23 AM »
OUCH! Not that it helps but we have all had models that ended up like you Vector for one reason or another. Good luck with the Cardinal, good flying airplanes. Shouldn't have too much trouble building up a fuselage, like you said just use the profile numbers and go for it.
Re: saito 40 Vector
« Reply #17 on: February 23, 2015, 06:39:55 PM »
Sorry to see your Vector go in.....
I had a Mustang given to me with a Saito .40 go in this past Summer due to a line clip freak accident. Crushing blow. I know the feeling.
It'll pass.
Offline Ehsan Morshedi
Re: saito 40 Vector
« Reply #18 on: June 13, 2017, 12:51:52 PM »
Hi every body
Has any body ever used an OS alpha 4 stroke on a F2B ship?
I'm planing to use an OS 56 alpha on a vector 40.
Any opinion and experience would be helpful.
Ehsan
Re: saito 40 Vector
« Reply #19 on: June 13, 2017, 04:14:46 PM »
Hi every body
   That seems to be an awful lot of power (and weight) for such a small model. People used 56 4-strokes on full-size airplanes very successfully, and this one is much smaller.
Online Robert Zambelli
Re: saito 40 Vector
« Reply #20 on: June 20, 2017, 06:02:34 PM »
Hi every body
Ehsan
Hi, Ehsan.
I've had almost every four-stroke single that OS made but I'm not familiar with the "alpha" designation or 56 size.
Please post some pictures of the engine.
Re: saito 40 Vector
« Reply #21 on: June 22, 2017, 06:23:37 PM »
Hi every body
Ehsan
Hi
You would want to use a 30 to 40 size on the  Vector 40, if you want to use only a 3 stroke , as it is near a Nobler  size  stuntship
maybe look at getting a lighter 4 stroke that does not weigh 16 ounces
something like a Saito 40
« Last Edit: July 04, 2017, 03:05:14 PM by RandySmith »
Re: saito 40 Vector
« Reply #22 on: July 04, 2017, 01:44:22 AM »
Hi, Ehsan.
Hi
Follow this link please
http://www.osengines.com/engines-airplane/osmg0956/index.html
Re: saito 40 Vector
« Reply #23 on: July 05, 2017, 12:45:10 PM »
WOW!
Interesting looking engine.
I guess haven't kept up with the newer OS engines.
