  • April 19, 2024, 06:30:39 PM
Author Topic: Nelson Engine  (Read 12534 times)
Nelson Engine
« on: August 19, 2016, 07:53:38 AM »
Was the head on the Mk100 made of magnesium?
Offline Les Akre
Re: Nelson Engine
« Reply #1 on: August 19, 2016, 12:59:31 PM »
Not a definitive answer, but the example I saw had an aluminum head with the non-push pull contrapiston.
Les
Offline Jed Kusik
Re: Nelson Engine
« Reply #2 on: August 26, 2016, 12:17:41 AM »
I was provided both mag and AL (non push-pull)heads, by Henry. The mag heads were (being polite) very difficult, would not hold temp
evenly. The mag case mk 100 was also nearly impossible to race consistently for the same reason. There were some people who did use
them effectively, but if you looked closely at their models, they had excellent air-handling and cooling systems. Most people then did not
understand the fine details of cooling. building a good/excellent model before modern molded bodies was truly an art form.
I still have those early heads and a couple of the gold mk100 cases. although much of the gold treatment has corroded away...mag!
Mag engine parts turned out not to be a really good idea.
Sincerely,
Jed Kusik
Re: Nelson Engine
« Reply #3 on: August 26, 2016, 09:51:36 PM »
When you're truly racing you're going to go down some unconventional paths that's for sure. I wanted to punch the middle out of the head and use it as a head clamp on an AAC glow. If it holds up mechanically on a diesel it should be ok on a glow I guess.
Offline Air Ministry .
Re: Nelson Engine
« Reply #4 on: September 14, 2016, 09:21:44 PM »
same bolt pattern as the super tigre, amougst others .
