  • April 19, 2024, 07:47:58 AM
Author Topic: Black exhaust goo?  (Read 9402 times)
Offline frank mccune
Black exhaust goo?
« on: October 13, 2016, 01:43:09 PM »
     Hi All:
     I was running my MVVS D7 today and the exhaust goo was jet black! I adjusted the needle valve and backed off the compression to where the engine was under compressed and missing.  No matter what I tried, the exhaust goo was sill very very black!  The engine started very easily and ran flawlessly.  Could it be bad fuel? Any suggestions?
        Tia,
        Frank McCune
Re: Black exhaust goo?
« Reply #1 on: October 13, 2016, 08:26:42 PM »
What fuel mix are you using?  I know from experience that over compression will cause some black crud to come out, also old kerosene.  The kerosene should be clear like tap water.
Offline Russell Shaffer
« Reply #2 on: October 13, 2016, 10:28:51 PM »
If you are using a muffler, a loose one will make lots of black stuff from aluminum wearing.
Russell Shaffer
Klamath Falls, Oregon
« Reply #3 on: October 22, 2016, 11:34:54 AM »
If you are using ether from a spray can it has a top cylinder lube in it that burns at a very low temp and comes out black as coal even if your engine is rich and undercompressed with a light load prop. It's not a problem but your engine will coke up a little faster.
« Reply #4 on: October 22, 2016, 05:47:37 PM »
A rattling through-bolt in the muffler will do it too. So will one or more loose engine mounting bolts. Black exhaust goo is always alarming, but I hope it turns out to be something simple just vibrating.
« Reply #5 on: May 27, 2017, 09:55:08 AM »
     Hi All:
     I found the problem and corrected it.  The rear of the rod was rubbing on the crank disk.  I filed the rear of the rod for adequate clearance.  End of problem  The engine runs like a Diesel should.
      Thanks for all of the help!
        Frank Mc cune
