  • April 18, 2024, 09:19:37 PM
Author Topic: Jeti Spin 66 pro compatible with Igor Burger controller/Accel?  (Read 15155 times)
Offline Mike Callas
« on: October 17, 2016, 07:44:29 PM »
I read in the previous posts that Igor"s setup is not compatible with the Jeti spin 66 Pro.
Is this still the case??
If so, is anyone supplying a "Non-Pro" version?
Online Tim Wescott
Re: Jeti Spin 66 pro compatible with Igor Burger controller/Accel?
« Reply #1 on: October 17, 2016, 09:59:26 PM »
Igor sells everything you need.  And, if the Pro will do the job, he probably knows.
Offline Russell Bond
  • Bandolero
« Reply #2 on: October 22, 2016, 12:40:11 AM »
Apparently the Pro is not fast enough with Igor's system. You need to get the older version Spin 66 from Igor.
Bandolero
Offline Igor Burger
« Reply #3 on: October 22, 2016, 12:52:59 AM »
Yes, exactly, PRO version does not have our mode of work (HELI 3D - mode of work with unlimited head speed change - normal heli mode has slow speed change to protect heli mechanic parts in transmission), It is simplified, unfortunately just the function which we need s missing.
However timer will work with any ESC, but the result is not proper, so I do not recommend to spend time and money making it work. Constant RPM will work well with them.
Offline Igor Burger
« Reply #4 on: October 22, 2016, 01:45:17 AM »
Here are menus for both spins:
non-PRO:
http://maxbee.net/download/SPIN_EN_menu.pdf
PRO:
http://maxbee.net/download/spin_pro_schema-de-en-cz-2012.pdf
and here is description how to programm non-PRO Spin for C/L use:
http://maxbee.net/articles/spinprog.htm
Offline frank williams
« Reply #5 on: December 10, 2020, 07:51:28 PM »
Am I correct in assuming that the Pro version will work with the constant RPM setting on the Spin 66 ESC.?
The non-Pro 66 3D=Heli is needed to have the freq response for the active accelerometer system.
Is this correct?
« Last Edit: December 10, 2020, 08:54:15 PM by frank williams »
Offline Igor Burger
« Reply #6 on: December 11, 2020, 02:08:32 AM »
Is this correct?
Hi Frank, yes, it will work ok with constant speed timer, just you must set all parameters separately, not like on non-pro version like "type of aircraft". It will also allow to set timer for 100% throttle and set rpm in ESC with jetibox (MIN and MAX with difference of 50 RPM).
Also be carefull what you do on those 2 servo cables, I am not sure if it is safe if your timer on one cable will start motor and you are on the another cable with Jetibox. Non-pro version cannot start in such mode, but this pro probably can, because jetibox is monitor of running parameters. I am not sure, it is necessary to test and be carefull.
« Reply #7 on: December 11, 2020, 01:00:22 PM »
Thanks Igor
I've been using your passive timer and esc to set rpm limits.
I have to disconnect black servo wire from timer when programming esc through red servo wire
Offline dc stunt
« Reply #8 on: June 28, 2021, 05:31:44 PM »
The only esc that works with my Plattenberg motor is Igor’s spin.
It has a very crucial function that no other esc has besides that heli 3D
. This particular esc has a motor pole function. By selecting the proper pole of
your motor, the calibration of ms matches between the motor and the esc thus
rpm can be set correctly where there are enough room for your Max/min.
I have tried using Talon 60 with my Plat and it didn’t work at all. Our initials are always set
at 2.0 ms/1.25ms.  So for the pwm to work properly. It’s best for our rpm to be some where
In the middle, can’t be too high or too low, otherwise there is no room to accelerate or decelerated.
L-201
