  • March 28, 2024, 04:34:31 PM
Author Topic: awker urricane  (Read 55831 times)
Offline Air Ministry .
awker urricane
« on: July 25, 2015, 09:17:53 PM »
As ive adequate Royal Blue Modelspan , thisll be Finished as Princess Margrets Aeroplane , the LAST Hurrican Built .
« Last Edit: July 25, 2015, 11:23:38 PM by Matt Spencer »
Re: awker urricane
« Reply #1 on: July 25, 2015, 09:23:44 PM »
Hunfortunately , I fink the 50 pixies devour one page .
at Zero or bellow , the Epoxy takes twenty four hours to ' kick off ' so we need ' means ' . This aint that , and the nose former canted a tad.
So we dont actually recomend it , but 40 minutes beats 1440 . If your patiance has evaporated .
Re: awker urricane
« Reply #2 on: July 25, 2015, 09:26:45 PM »
That was a heavy frost .  ;)
Re: awker urricane
« Reply #3 on: July 25, 2015, 09:29:16 PM »
RIGHT , where were we .  ;D
Re: awker urricane
« Reply #4 on: July 25, 2015, 09:31:29 PM »
sheeting / planking the upper forward .
Re: awker urricane
« Reply #5 on: July 25, 2015, 09:35:28 PM »
you can see the Bearers go aft to the wing spar .
Re: awker urricane
« Reply #6 on: July 25, 2015, 09:37:35 PM »
moore
in the cold the coffe gets cool before youve half finished it .  :-\
« Last Edit: July 25, 2015, 11:25:05 PM by Matt Spencer »
Re: awker urricane
« Reply #7 on: July 25, 2015, 09:44:24 PM »
Didnt getta picture of the three wing pieces . Outers and center section , which is Flat , the Outers run abouta inch of Diheadral .
You can see how the outer spar ( Obeche 1/4 x 1/8 0 drops down in front of the straight thru center ( spruce 1/4 Sq. ) one .
Re: awker urricane
« Reply #8 on: July 25, 2015, 09:46:14 PM »
Theres a few technical ( injuneering ) things I will relate later .
Re: awker urricane
« Reply #9 on: July 25, 2015, 09:47:54 PM »
so
Re: awker urricane
« Reply #10 on: July 25, 2015, 09:49:32 PM »
here
Re: awker urricane
« Reply #11 on: July 25, 2015, 09:52:09 PM »
We
Re: awker urricane
« Reply #12 on: July 25, 2015, 09:56:53 PM »
As the obnoxious young upstarts in our Torbay Club were so fond of saying ,
 besides ' whats the price of gold in China got to do with the Peking Fish Market '.
" You dont have to be mad to be a Aeromodellor. But it helps "
a few clues to other perscriptions .
Re: awker urricane
« Reply #13 on: July 25, 2015, 11:47:46 PM »
The things 1 1/8 times the 57 in ' Typical .46 ' one I did . This gives 125 % the Area, About 800 Sq. in here .
The Stalker 76 ( or 66 ) is Fitted . as it fitted .
The 57 in one had ' Canards ' The Exhaust Stacks were about 3/4 wide x 3 long , Ea Side of the nose .
Initially had a ' nose down left ' trim . Glareing along from Fwd. noted that one side was angled off C/L .
Fitting it straight got the trim level and neutral .
Idea was to see , if like a Kfir C2 , they were a " Lift Improving " device .
As the lateral trim is descerable if theyre angled , thyre definately ' aerodynamic'; up there . Which is a good start .
Other deviation from knomal is the Center Section SET UP .
The Trailing Edge and FLAPS are one line , Center to Tip .
Whereas;
The Center Section SPARS and LEADING EDGE are FLAT ( though Ive got a 1 m.m. drop to break on top surface ,so as it dosnt APPEAR sagged .)
Therefore Fwd of the Spars Symetrical with about 6 mm drop on the centerline of the T.E. GIVING a Assymetric Airfoil inboard .
The benifit of this Appears to be The Flaps are More Efficent at low movement INVERTED due to the deflection being IN LINE with
the Shallower Slope on the underside sheeting of the centersection , I presume .
As it Floats Through the downhill to intersection , inverted from the upper loop of the Vertical eight ;
giving you all the time in the world to ' hit the cut ' on the reversal to the top of the Inside .
Thats my theroy , in Hindsight .
Though theres a touch of wash out ( 2 mm ) Ea. Tip : which is ' Wash In ' INVERTED ! .  n1 you can detect this with the
' rolly feel '  ( balance point / instant resonce ) inverted .
This came about as Id forced the Sheet Fwd. and Aft. on the center ribs to make a STRIGHT LINE after Id Secured the T E to the outer Ribs .
Think about it , theres a shift in the l.e. of the T.E. at the Diheadral Break . It shifts the T.E. Sheet Top  aft a few m.m.
and the undersheet back a few mil.
Forcing thinto line sets the tips up about 2 m.m. at the trailing edge .
As it was Even / Symetrical ( side to side ) I thought it Easier to leave well alone and ' see what happens ' .
THIS ONE will get 1 m.m. Wash Out and carefully Trimmed & Cut Trailing Edge Sheets in there !
Back to The Grindsrtone . It still unused in its boox on the shelf .
Re: awker urricane
« Reply #14 on: July 26, 2015, 02:41:50 PM »
Get it clamped up in your cold, cold shop, then put it someplace warm to set.  My office is next door to my shop, and it's the only heated space in the building.  So in the winter* I get things clamped in the shop, then bring them in here for the epoxy to set.
* What passes for winter in the Willamette Valley in Oregon.  Minnesotans wouldn't even laugh because they wouldn't understand that five inches of snow here is a Horrible Storm.
Offline frank mccune
Re: awker urricane
« Reply #15 on: July 26, 2015, 03:09:46 PM »
     Hi Matt:
     I sent you a letter this morning.
     Great work on the Hurri!
     Good God man! Where do you live? What language do you speak? Lol
        Be well my friend,
        Frank McCune
Re: awker urricane
« Reply #16 on: July 27, 2015, 10:32:02 AM »
Matt,
That's actually a great aircraft your modeling, a good choice.  H^^
There's plenty of schemes, and a red aircraft if you do a  search.
Good luck!
Re: awker urricane
« Reply #17 on: July 27, 2015, 09:35:14 PM »
Red Hurricanes . http://s195.photobucket.com/user/marluc_foto/media/Hurricane/WhiteRusskieHurri002.jpg.html
http://i195.photobucket.com/albums/z27/marluc_foto/Hurricane/image.jpg
Found It.
most of it seems in pretty good order .
was supposed to go back to Russkie Land , after the poms do it up . But as theyre no longer holding hands ??
Was the Worlds Only Stirling to theyd lined up to go back to olde blighty . If they put all the polititians in a Orchestra ,
we'd find out if theyre capeable of anything inteligent . If they gave them all I.Q. Tests , theyd probably FAIL .
o.k.
« Last Edit: July 27, 2015, 10:11:24 PM by Matt Spencer »
Re: awker urricane
« Reply #18 on: July 27, 2015, 10:14:47 PM »
Be this if any other , Battle of France they ( the R.A.F.) wasted 1200 kraut aircraft , so not quite the walkover some portray .
« Last Edit: July 29, 2015, 07:54:49 PM by Matt Spencer »
Re: awker urricane
« Reply #19 on: July 29, 2015, 07:46:43 PM »
The Wing T.E. 1/2 done , with the hinge blocks clamped .
Re: awker urricane
« Reply #20 on: July 29, 2015, 07:53:19 PM »
Fully sheeted T.E. now , Did a Big Panic last night as sticks across viewed allong wernt parrallel .
Out with a carton of matchboxes , sticks , planks , mugs & coffe jars !  Shocked
Packed equal equidistant out  and aligned on the glass sheet , so the PVA dries with it IN ALIGNMENT .
A stack of equal sized wotsits put equal distances from centreline , or a bit inequal if you allow for the longer inner wing
and it should be equally straight or otherwise .
Re: awker urricane
« Reply #21 on: July 31, 2015, 09:16:16 PM »
more , if anyone gives a rats . . .
Re: awker urricane
« Reply #22 on: July 31, 2015, 09:18:43 PM »
Ucain .  :-\
Re: awker urricane
« Reply #23 on: July 31, 2015, 09:20:24 PM »
further
Re: awker urricane
« Reply #24 on: July 31, 2015, 09:21:42 PM »
& So Far .
  • Gravitywell
Re: awker urricane
« Reply #25 on: August 05, 2015, 09:56:36 AM »
Following very close behind (a tie?) the Spitfire as my all time favourite aircraft, the Hurricane!!  I am watching this with a lot of interest and waite patiently for each new picture update.  Keep up the great work Matt. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: awker urricane
« Reply #26 on: September 20, 2015, 08:48:04 PM »
found this , though the new ones chubbier in the Fuse , hold ups with getting a few other things done .
Once I get some decent dope , its back underway again .
Offline GregArdill
Re: awker urricane
« Reply #27 on: September 22, 2015, 12:23:37 AM »
Matt,
If you're looking for dope... Phoenix Lacquers at Bankstown have both tautening & non tautening.
http://www.phoenixlacquersandpaints.com.au/
Good product, reasonably priced.
Re: awker urricane
« Reply #28 on: January 06, 2016, 08:43:14 PM »
Gotta Gallon thanks . Got the Nitro Cellulose , as its Nitrate with fancy additives . :) Furniture Lacquer .  :P ^-^
Theser from  a week back . The assys ( Horiz. stab ) is done now , but I forgot to pictureise it . Will tryn remember to get a few shots with it thrown together , ive trimmed the wing cut outs out . Still to do the Vert. Stab. Need to do a plug to mould the LE . Then theres the U.Carrage . AND Im inclined to set it up for the G-51 as its about the right size and weight for how ive run em , rather than the Stalker 66 . Or maybe BOTH ,  H^^
theyre Big Cups .  LL~ S?P its about 21 in. span & 20 or 23 % area . One or the other , probably the other .  ;D
Re: awker urricane
« Reply #29 on: January 12, 2016, 04:27:33 PM »
Elevator L.E. is 1/2 Sq. set diamond style . Probably better to reduce out to match taper , Just catches the depth at first bay. the spars tapered a little. 1 mm per bay .
Re: awker urricane
« Reply #30 on: January 12, 2016, 04:29:56 PM »
weighs 23 1/2  Oz. as shown . Should perforate the bearers to loose that 1/2 Oz .
Re: awker urricane
« Reply #31 on: January 12, 2016, 04:37:39 PM »
Will get 2 mm , the dreaded .077 sheet . 5/64 th in real money , L.E. & center section sheeting .
trialed bent wire & mounts for retracts , looks like it'll fall in . So may give it a go .
1/4 rod with R & L H threads , a spool & two rubber bands , with a few catches to actuate would do it .
We shall see .
its the same as the silver sucker about 1/6th bigger With fuse 1/4 wider times 7/6 ish .
Must find some Carbon monofillament for the ' stringers ' under the tissue .
Carbon Veil would toughen up the center section , too .
Re: awker urricane
« Reply #32 on: November 04, 2016, 08:53:24 PM »
Nuffin Done on it Lately . But thought I had a R.C. car ' Tie Rod ' to retract / lower undercarrage .
 in fact worked out how to work it out . :-\
The tie Rods are set up rather ' bound ' so no free rotation . So this requires a RETHINK . As it'll only be used to LOWER the gear ,
we'll let you contemplate on that there for now .
Just Tripped Over THIS : Battle of France / Early Camo/ marking specs . Thought it'd be as good a place to post em as any .
http://www.hyperscale.com/2014/reviews/decals/x72193reviewmd_1.htm
http://www.britmodeller.com/forums/index.php?/topic/234996644-italeri-mk1-148/
« Last Edit: November 04, 2016, 09:13:58 PM by Matt Spencer »
Re: awker urricane
« Reply #33 on: November 24, 2016, 03:48:57 AM »
Did HRH actually fly it herself?
Offline Michael Boucher
Re: awker urricane
« Reply #34 on: May 28, 2017, 03:11:55 PM »
Hi Matt, Great looking Hawker Hurricane, do you have a picture of the finished model? Thanks, Michael Boucher
AMA 59633
Re: awker urricane
« Reply #35 on: June 18, 2017, 04:01:09 AM »
Finished ! Finished ?
Um.
Got about five airframes ' framed up ' ,
Finished the TYPHOON last weekend , Er . . .
$ Coats friday 9 several more in places ) in semi arctic conditions . . . a week lare its taughtened off .
However will ryb back . its just in silver and clear , as the excess Oz are aft , tho C G is only 3/8 aft of where Im Aiming , with that short nose .
Contemplating a lighter empenage wwith Al Rabe inspired lightness , rather than my Spuce & Stick struckture .
Likely Blue Tissue then , for the Hurricane .
Offline Steve_Pollock
Re: awker urricane
« Reply #36 on: May 15, 2018, 05:03:32 PM »
Robert Tuck's restored Hurricane is currently on display at the Pima Air Museum just outside of Tucson, Arizona.
