  • June 17, 2025, 07:23:26 PM
Author Topic: Master Engines made in Italy  (Read 1146 times)
Offline Gary Anderson
« on: June 20, 2009, 01:27:54 PM »
Hi Randy,
I have a Master Engine made in Italy. It has  the number 4 on it side, do you know anything about these engines? Its a nice looking engine, just not sure it would be any good for stunt. It looks like it could be close to a 19???? Nice gold head, ball bearing, seems lite??? Don't remember ever running her. It also has a nice muffler with the engine. Not sure what size prop to play with??? If you know anything about her I would appreciate any info, Gary
Gary Anderson
Offline dennis lipsett
Re: Master Engines made in Italy
« Reply #1 on: June 20, 2009, 01:34:23 PM »
As near as I remember the Master series was made by Chippola? Meaning Onion in Italian. Have no direct knowledge of the performance of that engine but do have an 09 diesel and a 15 and they run well. As to stunt, most that I know of were timed for high RPM. I'm sure that there are others that can supply better info then I.
Dennis
« Reply #2 on: June 20, 2009, 06:54:04 PM »
As usual, Dennis is right...but it is "Cipolla"...but it is pronounced "Chip-olah". Try a 9-4 prop and a .257" venturi. There are some good 9-4's and some that are good paint stix, of course. Adjust from there...it probably won't like a bigger prop. The '4' should stand for cc's, and a 4cc is a .25cid.   H^^ Steve
