stunthanger.com
Welcome, Guest. Please login or register. June 25, 2017, 01:13:26 PM
Pages: [1]   Go Down
  Print
Author Topic: Cox 049 High compression glow heads  (Read 139818 times)
Bernie Eisele
Guest
Trade Count: (0)
« on: August 14, 2009, 04:51:03 PM »
For those of you that have been waiting for Tee Dee glow heads, they are now in stock
http://coxengines.ca/product.php?productid=200&cat=4&page=1
Bernie
Logged
2016 supporter
Trade Count: (0)
Admiral
Online Online
« Reply #1 on: July 02, 2012, 06:24:46 AM »
The glow head in your picture looks like a standard low compressionn head.  Not circle of stars on top and no trumpet shape inside.  Will you be offering a replacement for the higher performance TeeDee's and Black Widows?
Logged
Bernie Eisele
Guest
Trade Count: (0)
« Reply #2 on: July 02, 2012, 09:39:43 AM »
They are 100% identical to the OEM Cox Tee Dee High-Compression glow heads except for the knurl (circle of stars) at the top.
We did not bother with the knurl as it would have cost another 50 cents and serves no purpose other than cosmetics to quickly differentiate it from the regular glow head. And, yes, the combustion chamber is trumpet shaped and identical to the ones Cox used to make.
See here:
http://coxengines.ca/cox-.049-tee-dee-glow-head.html
If you want the OEM packages ones, we still have a few in stock as well. See here:
http://coxengines.ca/cox-.049-tee-dee-glow-head-oem.html
Bernie
www.coxinternational.ca
Logged
2016 supporter
Trade Count: (0)
Admiral
Online Online
« Reply #3 on: July 04, 2012, 07:23:39 AM »
Thanks.  I don't really care about the decoration, on the combustion chamber.  Without a source of plugs, all the TeeDees and Black Widows will go by the wayside.  I've tried some of the adapter units, but always with a crippling loss of performance.
Logged
Andy Bush
Trade Count: (0)
New Pilot
Offline Offline
« Reply #4 on: March 28, 2015, 03:39:45 PM »
I have just purchased some of your 049 glow plugs to go along with my attempt to bring back to life engines that I had back in the 50s. I'm using new Cox gas, battery, etc and disassembled, cleaned, and then reassembled the engines (Golden Bees).
I'm not having much luck in starting them. My question is this. My memory is that the glow plug coil would turn reddish orange when tested...this was one way we would check for burned out plugs. I'm not seeing this at all with your new ones.
Also, I can't even get the engines to 'pop', let alone start. I can hear the glow plug 'sizzle' as I remember from back in the day. I'm priming as usual and making sure that I didn't flood the engine...to no avail.
Are these plugs supposed to glow red as I recall?
Any tips would be most appreciated.
Thanks!
Logged
Phil Krankowski
Trade Count: (0)
Admiral
Offline Offline
« Reply #5 on: March 28, 2015, 04:41:33 PM »
Yes, these glow red.  In sunlight you might not be able to see it, even if you cup your hands.  Try in a darker space.  If it sizzles it is good.
You can also put a small drop of fuel into the plug then hook it up and it will instantly boil out (and may catch fire, but only for an instant since it was a small drop of fuel!)
I suspect you are priming like a big engine (because of the sizzle), and spraying fuel into the OPEN exhaust port.  This floods the engine quite instantly.  Instead rotate the engine through till the exhaust is CLOSED and then let surface tension collect a drop of fuel in the exhaust port (only 1 of them).  Now when the engine is cycled through the correct amount of prime enters through the exhaust.
Now on a "dry" engine that has not been run in several days I do "flood" it, to make sure everything is wet with oil and fuel.  I clear the flood, fill the tank and then prime with the exhaust closed (like I just described).
Phil
Logged
Andy Bush
Trade Count: (0)
New Pilot
Offline Offline
« Reply #6 on: March 28, 2015, 05:47:17 PM »
Thanks, Phil. I was testing these plugs in the closed garage and was cupping my hand. No red glow at all. I tried putting a drop or so of fuel on the glow element expecting to see a bubbling as I remember from the past. All I got was a faint response. Voltmeter says the new battery is right at 1.5 volts. The Cox plug connector voltage checks OK too. I'm stumped!
Andy
Logged
Phil Krankowski
Trade Count: (0)
Admiral
Offline Offline
« Reply #7 on: March 28, 2015, 07:43:12 PM »
hmm...OK.  So minimal response.
What battery are you using?  If you are not using a 2D cell in parallel I would try one of those with fresh alkaline batteries.  I have a habit of suspecting power panels and rechargeable ignitors.  (Wire and tape work very well if you lack an alkaline tray, at least for a while.  These self-drain since you cannot break the circuit without taking it apart.  I made a tray from RadioShack parts when they were still around.)
If you are using an old Cox clip, I would suspect the wires, and probably clean the clip with some fine sandpaper.  The thin solid wires on those old clips break inside.  Get some lamp cord or speaker wire and replace the wire.
Fire off an email message to Bernie, the contact link at the top of coxengines.ca if the 2 D cells don't light it up, and you are sure your wiring is good.  I would be stumped too.
Phil
Logged
Andy Bush
Trade Count: (0)
New Pilot
Offline Offline
« Reply #8 on: March 29, 2015, 09:15:38 AM »
Phil
Thanks, Phil
I'm using one of the traditional 1.5v batteries sold in the LHS. It's new, as I said and its voltage checks OK as does the voltage at the Cox clip.
I'll try cleaning that clip as you suggested.
I've ordered a test stand for the larger engines...a question about those plugs...
I can't remember what size plug (short or long) is used. I'm going to start these engines: Fox 15 and 35, Torpedo 23 and 35, OK 29, Enya 19.
I've had that OK 29 since the 50s and have never been able start it...this time I hope to, it may take one of those electric starter thingies.
Logged
Phil Krankowski
Trade Count: (0)
Admiral
Offline Offline
« Reply #9 on: March 29, 2015, 10:46:48 AM »
Thanks, Phil
A battery can test with good voltage, yet when a load is on it the voltage drops.  Try the D cells, even if just a temporary setup.
As for the glow plugs "yes"  Out of 3 differed fox 15's 3 different plugs may be required...
Phil
Logged
Andy Bush
Trade Count: (0)
New Pilot
Offline Offline
« Reply #10 on: March 29, 2015, 11:35:10 AM »
Good news!
The glow plugs seem OK.
I found that the Cox glow plug clip wasn't making good contact. I wiggled it around and saw the glow element turn red as we have discussed. So, on to the test runs!
As for the larger engines, the Fox 15 is late 50s, early 60s vintage, used for control line flying, nothing fancy. I bought plain jane short and long Fox plugs. I imagine the 15 takes the short...is that correct? The 35 maybe the long?
Logged
Phil Krankowski
Trade Count: (0)
Admiral
Offline Offline
« Reply #11 on: March 29, 2015, 12:56:15 PM »
Good on the clip!
The fox 35 can take an OS#8 as well.  Many will say it is a better plug, but a good plug is a good plug.  Getting the desired performance and a clean run is what tells this in the end.
I know my fox15 from the 80's takes a short or the piston hits, it is an early Schnurle BB.  I recall a slant head fox15 I used to have using a long though, but cannot confirm that as I don't have the engine anymore.
I don't know anything about the other engines listed.
Phil
Logged
Andy Bush
Trade Count: (0)
New Pilot
Offline Offline
« Reply #12 on: March 31, 2015, 08:58:30 AM »
Thanks, Phil
I ordered a test stand to fire up my larger engines. Got it in the mail yesterday and once I get it mounted to something, I'm ready to go.
But I'm uncertain about how to mix enough castor oil into the commercial fuel. I've heard that 4 ounces per gallon should do it.
Do you have any advice on this?
Andy
Logged
Phil Krankowski
Trade Count: (0)
Admiral
Offline Offline
« Reply #13 on: March 31, 2015, 01:10:35 PM »
Look at what you are starting with and then figure out where to go.  You really are best off buying the correct blend to start with.  Sig Champion 25%
http://sigmfg.com/cgi-bin/dpsmart.exe/ProductsV6.html?L+Sig+gikj7197+_Ddp_5fSearch1_02a41FuelSigChampion_01Search_02Index_01SubMenu_02NONE_01Menu_02CatProd_01Thumb_02Fuel_20_2d_20Airplane_01
and the NEW formulation of Cox glow fuel
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDBNH&P=ML
There are other companies that blend fuel too, and if they offer a suitable product then feel free to use it.
Quarts are not hazardous shipping, just ground only.
The "ideal" fuel for Cox is 10% castor, 10% synthetic oil since the ball joint in the piston will be lubricated properly by this.  Full 20% castor is another choice but it will build more varnish than necessary and the engine will need cleaned more frequently.
The Fox 35 wants a rather different blend.  I ordered through Brodak.
http://brodak.com/fuel-qt-5-nitro-29-castor.html
This is a pretty good fuel, I like it.
I don't know the requirements of your other engines.
A few years ago I wrote a spreadsheet to figure the oil requirements to blend some off the shelf fuel (it is not on this computer though).  I have not yet finished that gallon because I just bought fuels for each engine...
Phil
yes, I believe 4 oz will put you in the ball park with 18% oil fuel.
Logged
Andy Bush
Trade Count: (0)
New Pilot
Offline Offline
« Reply #14 on: March 31, 2015, 06:08:59 PM »
Hi Phil
First, I added 4oz of castor oil to the gallon of fuel (15%) that I got at the LHS.
Then I mounted my OK Cub .29 and gave it a try. Now, this is an engine that my memory tells me I never got to run.
I didn't hook up a tank, just went with the primer fuel to see if it would even fire.
Whoa doggy!! That puppy fired right up and ran for a few seconds until the prime was used up. I was so happy I could...well, you know what I mean!!
Not having the same luck getting the 049s running. I need to get one going, then I'm going to build a profile version of the Veco Squaw (no flaps, solid wing) and let him learn on it.
It's good to be back in the hobby!
Andy
Logged
2016 supporter
Trade Count: (0)
Admiral
Online Online
« Reply #15 on: March 31, 2016, 09:01:35 AM »
For best results, spend $29.95 for a Tower or Hanger 9 power panel and another $30 or so for a sealed lead acid 12 volt battery.  Then you can adjust the glow to the color you want and ENJOY modeling.
Proper glow power is one of the key elements of "gas engine" flying.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.21 | SMF © 2015, Simple Machines
Valid XHTML 1.0! Valid CSS! Dilber MC Theme by HarzeM
