stunthanger.com
CLICK HERE---->    <----CLICK HERE
Welcome, Guest. Please login or register. March 25, 2017, 01:48:48 AM
Pages: [1]   Go Down
  Print
Author Topic: Lost Foam  (Read 553 times)
Motorman
Trade Count: (0)
Admiral
Offline Offline
Millville NJ PDQ Flying Clown Country
« on: February 26, 2017, 07:42:45 PM »
Does Core House make lost foam jigs and bucks?
Logged
There will be a sunny day and we will fly our airplanes.
phil c
Moderator
Trade Count: (0)
Admiral
Offline Offline
« Reply #1 on: March 10, 2017, 11:08:04 AM »
We can, once I get the foam cutter running again.  The blasted thing stopped cold one day and totally would not work.  The programming for most foam cutters I've looked at is very narrow minded and aimed at machinists who like Gcode and run CNC mills or lathes, or at RC gliders and vacuum bagging.
As far as lost foam, if you like building, like to paint 19 point finishes and are good at it, lost foam is very good.  If you prefer flying the "lost wood" construction method is easier and quicker.  Build the same wing with solid foam with spars and tips and skip most of the wood and building.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.21 | SMF © 2015, Simple Machines
Valid XHTML 1.0! Valid CSS! Dilber MC Theme by HarzeM
