  • March 28, 2024, 07:09:19 AM
Author Topic: Prowler  (Read 4242 times)
Offline Larrys4227
Prowler
« on: February 09, 2017, 02:58:15 PM »
Charles ... You wouldn't happen to have the "Prowler" graphic archived somewhere, do you? My kit didn't have the decals/vinyls .... but it does have the graphic on the box.  I could scan it if need be .... wanna check with you first.
Larry
Lakeland, FL
Re: Prowler
« Reply #1 on: February 09, 2017, 03:26:58 PM »
Larry
Lakeland, FL
Larry,
You'll have to put up the box or graphic or whatever you have. Tight photo could work.
Charles
Offline Larrys4227
Re: Prowler
« Reply #2 on: February 09, 2017, 04:26:57 PM »
Larry,
Charles
No problem ... I'll work on it and get back to you.
Thanks for responding, Larry
Re: Prowler
« Reply #3 on: February 10, 2017, 03:57:57 PM »
Hope this helps.....
Re: Prowler
« Reply #4 on: February 10, 2017, 04:23:30 PM »
Shug,
Yes it does, thank you.
Charles
Offline Larrys4227
Re: Prowler
« Reply #5 on: February 11, 2017, 05:05:24 AM »
Thats great Shug .....  Thanks!
I did get the box label scanned to PDF ...  I just hadn't sent it off yet.  At a 1:1 scale, its alittle small ..... 25% larger would be good.  We'll also have to discuss my AMA number for the other wing, color, and a couple other needs I have.
Probably a week or two away from painting the plane and I'll finialize what color(s) I want ....
Re: Prowler
« Reply #6 on: February 11, 2017, 05:59:55 AM »
Larry,
I'm all set with the "Prowler" graphic.
I'll need sizes and color.
Charles
Offline Larrys4227
Re: Prowler
« Reply #7 on: February 23, 2017, 05:04:15 AM »
PM sent ....
Re: Prowler
« Reply #8 on: February 25, 2017, 05:27:37 AM »
Larry,
Your graphics will go in the mail Saturday or Monday. Everything is completed to your measurements and specks.
Here's how I see your order on my monitor. Yes, you choose the top graphic, white outline on everything.
With your trim design you should have a great looking model!
Charles
Offline Larrys4227
Re: Prowler
« Reply #9 on: March 02, 2017, 04:25:18 AM »
Received Charles ... exactly what I asked for, and should look nice.
Thank you!  Larry
Re: Prowler
« Reply #10 on: March 03, 2017, 06:28:13 AM »
Thank you!  Larry
Larry,
Progress photos?
That's a very popular model. They pop up on ebay from time to time. Tempting.
CB
Offline Larrys4227
Re: Prowler
« Reply #11 on: March 03, 2017, 07:53:39 AM »
Larry,
Progress photos?
Not yet .... final color will be sprayed this weekend, then a couple weeks to gas-off gives me time for final assembly.
Theres a thread I started on this plane around here, somewhere, from 2015 ... I'll finish that thread off with a few pics.
Thanks .....
Re: Prowler
« Reply #12 on: March 29, 2017, 09:39:20 AM »
Nice job Larry.
Outstanding in fact.  H^^
Charles
