  • April 25, 2024, 09:29:56 AM
Author Topic: The TERCEL building thread  (Read 5515 times)
Online Mike Griffin
« on: January 23, 2017, 02:14:23 PM »
This is a thread showing the building progress of Keith Trostle's design, the TERCEL.  I am building the wing first.  The first set of pictures will show the construction of the wing on my Jig.  Feel free to ask questions as the build progresses.
NOTE:  This wing jig was originally sold by Jim Snelson.  Jim no longer is in the business and Jim Lee now makes these jig brackets in case you are interested.
« Last Edit: January 23, 2017, 04:29:03 PM by Mike Griffin »
Online Mike Griffin
Re: The TERCEL building thread
« Reply #1 on: January 23, 2017, 02:34:04 PM »
Next set:  Bushed 1/16 Ply Bell Crank.  This comes with the plywood parts in the kit.  It is installed as a suspended bellcrank.  Slide the bell crank to the center of the short piece of 1/8 " music wire which is the pivot post.  Slide a washer on each side of the bellcrank and then slide two pieces of fuel tubing over each end of the music wire to keep the bellcrank centered.  On a 1/2A ship this will work just fine. The top and bottom ends of the fuel tubing are cut so that they rest against the face of the plywood bellcrank mount piece.
« Last Edit: January 23, 2017, 04:16:55 PM by Mike Griffin »
Online Mike Griffin
« Reply #2 on: January 23, 2017, 03:59:24 PM »
Gluing up the plywood flap horn.  The plywood flap horn is laser cut and included in the sheet of plywood parts.  Cut a piece of 1/8 x 1/4" spruce as shown in the below picture to the proper length, mix up some epoxy, take a toothpick and apply some epoxy inside the square hole on the ply horn and mark the center point on the length of the spruce stick, slide the horn over the stick and let dry.  In the next set of pictures I will show you how the horn is glued to the flaps.
« Last Edit: January 23, 2017, 04:24:42 PM by Mike Griffin »
Offline Skip Chernoff
« Reply #3 on: January 23, 2017, 04:50:50 PM »
Thanks for sharing. That jig makes a lot of sense.Nice job BTW
Online Mike Griffin
« Reply #4 on: January 24, 2017, 08:43:04 AM »
This shows how the flaps are connected with the piece of 1/8" x 1/4" spruce.
Offline Target
  • C/L Addict
« Reply #5 on: January 25, 2017, 01:38:44 PM »
Subscribed.
Chris
AMA 5956
Offline Bill Ambrose
  • Bill Ambrose AMA 880
  • Definitely NOT a "new" pilot
« Reply #6 on: January 27, 2017, 06:37:21 AM »
Mike,
I ordered a set of wing jig brackets from Jim Lee.  Thanks for the tip.
Bill Ambrose
AMA 880
Offline Serge_Krauss
« Reply #7 on: January 27, 2017, 05:23:17 PM »
Nicely done and shown, Mike!
Online Mike Griffin
« Reply #8 on: January 28, 2017, 04:24:03 AM »
Thanks guys.  I will be getting back to the build shortly.  Had some family business that needed tending to but will be back at the bench in a couple of days and will have more pictures for you...
Online Mike Griffin
« Reply #9 on: February 03, 2017, 04:09:28 PM »
Here are more pictures of the build.  You have the parts to build either vertical fin.  I am showing both.
Online Mike Griffin
« Reply #10 on: February 03, 2017, 04:11:50 PM »
Here is the stab and elevator
Offline Steve Thornton
« Reply #11 on: February 05, 2017, 06:31:27 AM »
Great job again Mike, of both building and posting.  Is the Tercel one of your kits?  I'd sure like some more info on it and where I could get one.
Hope all is well with you guys,
"Most of us won't make it out of this world alive."
Steve Thornton
« Reply #12 on: February 05, 2017, 06:35:29 AM »
Sorry Mike I didn't read down far enough...I may be old but at least I'm slow!
Steve Thornton
Online Mike Griffin
« Reply #13 on: February 05, 2017, 04:14:00 PM »
Hi Steve
Keith Trostle designed it and RSM Distribution sells the Kit.
Offline Keith Renecle
« Reply #14 on: February 07, 2017, 12:04:40 AM »
Hi Mike,
Just one question...how do you bush those holes in the plywood horns and bellcrank? The bellcrank line holes look like small eyelets, so do you have a press or something? Thanks.
Keith R
Keith R
Online Mike Griffin
« Reply #15 on: February 07, 2017, 07:05:19 AM »
Hi Mike,
Keith R
Hi Keith
I do not do that.  Eric Rule at RSM does that and includes it in the kit.  You might drop him a note and ask him how he does it.
« Reply #16 on: February 07, 2017, 10:18:42 PM »
Thanks Mike, I'll check that out with Eric.
Keith R
« Reply #17 on: April 20, 2017, 10:25:32 AM »
Mike,
What's the status of the Tercel build?
Bill Ambrose
AMA 880
Offline Jim Oliver
« Reply #18 on: August 17, 2017, 06:27:57 AM »
Any progress Mike?
Jim Oliver
AMA 18475
